Lowering the A6: Seeking Reccomendations
#11
#12
I just took measurements.
Right now, here are the gaps between the tires and the outside fenders.
Fronts: 2.75"
Rear: 2.25"
If I could bring the gaps down to around 1" or 1.25", I think it would look really good.
Would I only need springs to accomplish this?
Fronts: 2.75"
Rear: 2.25"
#14
Thanks, I understand that how much your car will be lowered depends on if you have the factory "sport suspension" package or not?
And what did you use for your springs? H&R, Eibach, Bilstein, etc?
Did you also get new struts/shocks with the springs?
#16
[QUOTE=Linkers033;24813866]
Thanks.
How long had you had the H&R springs? Do you feel like ride comfort or handling got any worse with the new springs compared to stock springs?
Thanks.
#17
I would highly recommend a quality lowering spring that offers minimal lowering like an H&R Spring. If the ride quality / damping is not what you want or after a while you find the stock shocks have degraded in performance, I would highly recommend Koni Sport Yellow replacement shocks. They offer excellent quality, designed for stock or slightly lowered vehicles, and priced right. You can also adjust the damping to suit
#18
Thanks for the input.
I am trying to decide between the HR and Eibach springs. What are the key differences between these 2, besides the lowering height? Are they both quality products made in Germany? Does one have better ride/handling than the other?
#19
The following is mostly opinion: I have run both the Eibach and H&R springs. They are probably very comparable. I know the Koni Sport shock kits if ordered with springs come with H&R springs. H&R springs are popular with German cars since they are German made. I am of the opinion that H&R springs are more custom made for each vehicle where as Eibach are more mass produced and perhaps not as finely tuned to the vehicle? I have noticed that H&R springs seem to be the same drop front and rear which will keep the balance the same as stock. Eibach may have a different drop front and rear and designed more for looks? I have not researched this as it pertains to our cars but have seen this broadly in the past.
#20
Thanks for the opinion.
Important question. Does any one know if changing the spring and/or struts on the car would void warranty? My A6 is less than a month old. Can anyone confirm?
