Oil drain plug ?! (trying to change oil)
Old 11-07-2012, 03:38 PM
  #11
SSA6's Avatar
Originally Posted by Badtone
I used a MityVac 7201 and sucked the oil out through what would normally be the dipstick tube. I was concerned about getting all of the oil out, but my 3.0 holds 7.2 quarts, and it took 7.2 quarts to fill it back up. This is apparently how the dealer does it, and it is much simpler and less messy than using a drain plug. With the top mounted filter there's no need for a jack. I'm assuming the 2.0 is setup for this as well.
My exact experience also with the MityVac 7201. Very easy with no mess.
Old 01-20-2013, 02:56 PM
  #12
j11940's Avatar
Originally Posted by j11940
Hey Guys,
Im trying to change the oil on my 2012 A6 C7 but I can't find the oil drain plug in the oil pan. Has anyone changed there oil and located it? I find it pretty strange I cant locate the the bolt. And yes I removed the under plastic panel.. I see the oil pan but no plug...
Thanks!'
John
It's official there is no drain plug, I asked the dealer. I decided to use a hand pump and it took 1.5 days to empty the oil, it was horrible. Apparently you need to buy a motorized pump to change your oil now, ugh...! I think I may actually take it somewhere next time, not worth my time...
Old 01-20-2013, 04:17 PM
  #13
ericgl's Avatar
On my 3.0 I can suck the oil out in 5 to 10 minutes with a Mighty Vac.
Old 01-20-2013, 08:24 PM
  #14
Grapeking's Avatar
I am amazed they would design and build an engine with no drain for the oil. Guess I'll be acquiring a new tool - a pump.
Old 01-21-2013, 05:11 AM
  #15
snagitseven's Avatar
But just think about how much weight savings is achieved by eliminating the plug.
At least .000001 MPG improvement.
Or maybe there's another reason?
Old 01-21-2013, 05:49 AM
  #16
salvadorik's Avatar
To make it intentionally more complex so that the customers resort using delear services rather than doing themselves?
Old 01-21-2013, 07:11 AM
  #17
Grapeking's Avatar
The cynic in me believes this to be the truth behind the matter.
Old 01-21-2013, 09:40 AM
  #18
Jatmobil's Avatar
Not sure what the dealer is smoking [whatever it is, I would like some ]
I have been under my 2012 A6 2.0T and have seen the drain plug. If I recall correctly, it was a 10mm Hex type. For the record, I still suck the oil out of the dipstick tube as it is much easier! I do however get under the car every other oil change to make sure all is well!
take a look at this link below, then also click on the exploded view parts diagram!
http://www.audionlineparts.com/parts...20drain%20plug
TheStigOnline (04-11-2022)
Old 01-21-2013, 04:41 PM
  #19
Grapeking's Avatar
I wonder if the 2.0T has a drain plug, but the 3.0 doesn't?
Old 01-21-2013, 05:08 PM
  #20
04_ultrasport's Avatar
Yes they both have drain plugs. Whatever dealer said they don't needs to learn there product. The 3.0 has a 6mm hex to remove it and the 2.0 takes a 19mm wrench to remove the drain plug. They are both on the left side of the pan but the 2.0 is angled and the 3.0 is point straight down.
Quick Reply: Oil drain plug ?! (trying to change oil)
