Rolling back on hill
Old 04-09-2014, 12:43 AM
kevinsong's Avatar
Default Rolling back on hill
My parking spot at work is in the basement. There is a gate in the middle of the up hill. I have to stop and flash my card and wait for the gate to be open and then drive out. At the gate, when I released the breaks my car would roll back. I was very surprised. It wasn't really sharp hill at all.
Previously I had Japanese cars and I drove that ramp many times and I never had this. And I thought automatic shift doesn't do that. Am I wrong?
Old 04-09-2014, 04:55 AM
James517's Avatar
AFAIK, there is supposed to be a hill holding feature on the A6 that will momentarily hold the car while you move your foot from the brake to the accelerator. In your case, the obvious possibilities are:
- the hill isn't steep enough to engage that feature
- you're wanting it to hold too long and it's letting go
- or there is a failure and it should be checked by the dealer.
Will be interested to learn what you determine is the issue.
Old 04-09-2014, 09:58 AM
PJRed2008's Avatar
That would be your left foot.
Old 04-09-2014, 10:46 AM
u2jrmw's Avatar
My 2013 A6 Prestige has hill hold (as did my 2010 A4 Premium Plus). Firm brake on the hill, it holds fine indefinitely until I pull away.
Old 04-09-2014, 11:58 AM
Banned
Mike_L's Avatar
The 2.0T may have a very loose torque converter. Its a very small turbo motor, so it needs to be able to get the revs up quickly so it doesn't trip over itself. If they give it a higher stall speed, the converter will allow the motor to spin up quickly and get into boost. Unfortunately, a higher stall means a looser converter, so it may not hold the car in place on an incline.
Old 04-09-2014, 12:54 PM
newmoon's Avatar
This is correct.
Also, it appears that the OP has the CVT which has a multiplate clutch and not a torque converter, so it does not constantly apply drive creep. If the hill hold feature is not holding the car, there may be a split second delay while the clutch engages, during which the car may roll back.
In these cases, it would be a good idea to engage the electronic parking brake. It will hold the car and release automatically once you press the gas pedal.
Old 04-09-2014, 03:07 PM
keithl's Avatar
My 14 Pretige has hill hold, even as I coast toward my driveway waiting of the garage to close the hill is slight, but I feel the hold kick in and stop the car and when I hit the gas I feel the brakes let go.
Old 04-09-2014, 03:16 PM
Banned
Mike_L's Avatar
Originally Posted by newmoon
This is correct.
I thought only the Premium was available with FWD and the CVT? Premium Plus should be a Quattro with the 8 speed auto.
Old 04-09-2014, 03:47 PM
Glacier6's Avatar
No, they offer a Premium Plus CVT as well.
manny calavera
A6 (C7 Platform) Discussion
23
04-12-2016 04:17 AM
Jeff
20
08-01-2012 07:55 AM
snagitseven
27
07-08-2012 02:19 AM
Chad J Goertzen
11-27-2010 07:50 PM
Big D
10-29-2001 05:53 PM
Quick Reply: Rolling back on hill
