2.7T 6MT - Timing Belt Kit / All Gaskets / Starter Installation
#31
Congrats GSRob! Its a good feeling when things come together in the end.
I had success bleeding air out of the coolant system by raising the front end of the car on ramps and running the engine until hot (with the heater set on high). This seemed to allow any air bubbles/pockets to travel out of the heater core and back to the radiator or reservoir.
#32
Thanks for the suggestions guys, I'll try both when I get home. So far it's running great. I've put about 3 hours of driving in at some pretty descent RPMs, going over the Blue Ridge mountains with the wife to see the colors of fall. Still no leaks, no burning oil smell (except for the initial burn off when I first started it), and it sounds good. Check engine light must have been on for the intercooler pipe leak before. I'm guessing that was also causing my random misfire code. I'll try bleeding it both ways when I get home and hope for heat at idle!
Just a suggestion for anyone about to do the timing belt service on their 2.7/2.8... Look up EWK Tools on eBay if you want a super cheap camlock bar and crankshaft pin kit. I think I paid like $38 with free shipping. The quality was way better than I expected and I got it 3 days after paying for it. Just be careful to differentiate between the V6 and V8 lock bars because the auctions look the same.
I think this is everything I replaced minus the accessory belt that I threw out right away.
#35
I have been able to bleed the heater hose by unscrewing the coolant reservoir and raising it above the heater hose connection. I think you might even be able to get the air out of the heater core by just running the engine with the reservoir raised and heat set to high temp.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
N'Syncro
33
02-16-2020 03:12 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
ECS Tuning-Audi
09-02-2015 11:39 AM
