2000 2.7T Engine coolant drain location
Old 05-22-2010, 06:34 PM
Floydo's Avatar
Default 2000 2.7T Engine coolant drain location
Moving into a coolant flush along with TB change, and the block drain is a puzzle. Comments mention a 8mm allen bolt. I believe I have one that requires a 6mm and is Very tight (the gold one); and there are two bolts in the area. Am I looking at the correct bolts? If so which bolt is it, left gold or blue right?
Thanks
Old 05-22-2010, 10:08 PM
monkeytronic's Avatar
ELSA only mentions one plug in that location (see diagram V10-1170 below) for a '00 2.7T which looks like the left most gold one in your pic....
Old 05-23-2010, 06:27 AM
Floydo's Avatar
[QUOTE=monkeytronic;23980266]ELSA only mentions one plug in that location for a '00 2.7T which looks like the left most gold one in your pic....
QUOTE]
That was my guess and Bentley (ELSA&Bentley same?) shows same pic, it is not quite a straight shot with a wobble adapter due to the washer on the horizontal bolt below and is tight enough that it felt like it might "go", plus the 8mm comment gave me pause...maybe it is time for another tool...a very long socket allen to alleviate the off angle. I'd feel better cranking on it if it were 8mm...or maybe take the horizontal bolt out...
Thx!
Old 05-24-2010, 06:59 AM
massboykie's Avatar
Thanks
Wow, I cannot believe there is not a drop of rust anywhere there. Damn NE weather sucks! LOL!
Cheers
Massboykie
wndysrf
12v V6 Discussion
11
06-20-2018 12:14 PM
sidespar
02-05-2008 02:36 AM
TheSkinFox
12-25-2006 06:45 PM
520
12-15-2002 02:11 PM
titanium
08-06-2002 09:39 AM
Quick Reply: 2000 2.7T Engine coolant drain location
