A6 2.7t wont crank at all. Dont hear starter
Hey i got a 04 audi a6 2.7t with auto trans. I went to start my car but it doesnt crank at all. Cluster and all electronics work. But car wont crank at all. I cant find the starter as well as i know where the fuse would be located under the steering wheel but cant figure out which fuse it could be. Can someone please put me in the right direction.
Since you have an automatic, there is a starter interlock relay. Try the following:
1) Set handbrake,
2) Turn ignition switch to run position.
3) Foot on brake pedal.
4) Shift to Neutral.
5) Try starting car.
If this works, it is possible that it is your neutral safety switch. If not, it is possible that it is the starter.
Don't panic. If you have an Audi, you need to be prepared for the days that your car has problems. Buy a bicycle or a friend with a reliable car.
Charge the battery overnight (12 hours) and then load test it or try to start the car.
You might try jumping the battery as well.
Amazing how many people leave the interior lights on in the back seat…my daughter has done it several times but I've caught it in the dark garage.
I checked battery is 12.6v. Car charges fine . And yes i tried switching to nuetral and starting. But no crank at all as well. I dont hear spinning what so ever. Also i heard the ignition switch could play a part how is this tested?
I just got her to start it slowly crabked once then started up. Im thinking that the ignition switch is to blame. Becuase now it fires up no problem but i see the cluster blur out and the radio has restrated while the car was running. Am i right that its the ignition switch?
monomoy4
Q5/SQ5 MKI (8R) Discussion
09-24-2015 05:13 PM
Captain Rossness
Audi A3 / S3 / RS 3 MKII
26
09-24-2015 05:34 AM
