A6 Steering Column Cover Removal
Old 10-25-2009, 08:58 AM
bfbarosky's Avatar
Default A6 Steering Column Cover Removal
So far I have removed the 2 torx screws from the underside of the cover & the 2 phillips screws in the front of the lower cover. Lower cover just will not come off. Appears to be some attachment point near the steering wheel, but I can't see anything.
I need to replace the W/Washer lever assembly (my 19 year old broke it off somehow).
HELP!
Old 10-25-2009, 09:57 AM
radhaz's Avatar
Looks like you need to remove the steering wheel.
Old 10-25-2009, 10:28 AM
Tech Guru
4Driver4's Avatar
I've done this, but I don't remember. When I did the evaporator swap, I used Bentley. I have a fair amount of Audi experience and mad skilz, but after using Bentley it is clear to me that I would have broken a ton of plastic parts if I had not carefully followed the Bentley.
Old 10-27-2009, 12:21 PM
Boston Driver's Avatar
There is one more torx bolt near the tilt lever on underside, but you will need to remove the steering wheel anyway to replace the wiper stalk.
Refer to this article which gives more detail on the stalk replacement (for the signal stalk but they are attached to each other): https://www.audiworld.com/tech/elec162.shtml
Refer to this writeup for info on the steering wheel column trim for a non-4.2 (my 2.7T):
https://www.audiworld.com/forums/sho....php?t=1702901
Good luck!
Old 10-31-2009, 05:21 AM
bfbarosky's Avatar
Good luck!
Many thanks. This is my project for next weekend. Need to find the parts first.
My A6 also has the turn signal problem you mentioned. But mine makes a very fast clicking noise in the dash, behind the radio - Relay Problem???
Usually, after I operate the 4-way flashers for a few minutes, the turn signals work, but only for a few seconds.
psuaudi
05-11-2007 02:47 PM
94' Pearl 90QS
6
04-07-2006 05:04 AM
RalliSport Ron
08-24-2004 08:29 AM
V8fan
Audi 100 / A6 (C4 Platform)
07-09-2003 11:43 PM
Quick Reply: A6 Steering Column Cover Removal
