Brake caliper replacement
So I just bought a 01 a6 2.7t that needed front pads and one of the front calipers replaced. I bought the caliper ahead of time not knowing it had a twin piston caliper (bought a single piston). This may be a stupid question but I was wondering if I could replace the larger caliper with the smaller single piston caliper.
Probably would need to replace the rotor as well
I think they are different rotor diameters/offsets.
It would probably work well enough to drive, but might not be safe.. I'd have some concern with the left & right not matching.
Yeah...buy a new carrier bracket and then get a new caliper and carrier bracket for the other side ...I believe the knuckles are the same, so you CAN do it.
I think I would just buy the right dual piston caliper and be done with it.
As 4D4 pointed out...you are on here asking this question for a reason...because you already know the answer and you are hoping someone will tell you otherwise.
Being cheap when it comes to brakes is low probability gambling of the worst kind.
Buy the right four pad caliper and return/sell the single piston one on ebay.
well, needed or not having two different front calipers will be a real recipe for disaster. Different clamping pressures, different threshold pressures, wow. Get the right thing.
G
G
But otherwise I agree with the other ones that putting a different type of caliper is a no go(and I'm going to throw a virtual rock at you too if I see you driving with different calipers (sarcasm)
N'Syncro
33
02-16-2020 03:12 PM
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
Optimusglen
09-02-2015 07:24 AM
elem
09-02-2015 02:20 AM
