Brake line screw up...
Old 06-25-2016, 12:25 PM
tester123's Avatar
Default Brake line screw up...
Hello Forum, it's been a while...
Tried to change the "flexible" brake hose (rubber sleeve torn from abuse during brake jobs / pad & rotor changes etc.) which is not leaking but won't pass inspection.
The issue is that when trying to loosen the nut for brake line, the entire line was turning/twisting... PBlaster etc. even then it's not moving. It moved a little because now I have fluid leaking out like crazy but rubber hose part won't turn.
Does it mean I need a new line? Perhaps, the question I should ask is, if that nut/end fitting of brake line goes, what repair(s) can be done ? Or, the line needs to be replaced?
Old 06-25-2016, 06:48 PM
SloopJohnB@mac.com's Avatar
Default Had same problem on my S6 but used a propane torch
On the connection with PBlaster. Be careful not to get it too hot, out just want to break the rust or corrosion loose. Might take a couple hot/cold cycles. F it won't break loose you'll probably twist the line and have to replace it.
Old 07-13-2016, 09:10 AM
tester123's Avatar
Thank you SloopJohnB. Ended up having the "experts" at midas fix it -rather butcher and splice it to extend and put new fitting. Not what I wanted to do but had no choice with my current living situation.
Old 07-13-2016, 11:10 AM
Default OK. Save your receipt for when it leaks.
Those double flared or bubble flare brake line ends are tricky. I trust they used a decent brake line rather than copper tubing!!!
gee2dasahn
S6 (C7 Platform) Discussion
13
04-18-2016 09:15 AM
klapp05S4
04-14-2016 09:17 PM
Howard Kim
12-22-1998 03:31 PM
jfl
10-26-1998 04:43 AM
Timothy Buck
10-23-1998 06:59 AM
Quick Reply: Brake line screw up...
