camshaft 2.5 tdi help
Old 02-18-2015, 08:15 AM
akberkes's Avatar
Default camshaft 2.5 tdi help
Hi
doing some work on my a6 i had some knocking sound coming from the engine i have been told its the hydraulic valve lifters i took the car to the mechanic to have a look..just wondering when the camshaft needs to be changed how do i know its bad ???
Thank you
Old 02-18-2015, 08:23 AM
jcman's Avatar
Originally Posted by akberkes
Hi
Thank you
Why would you be concerned about the camshaft if the problem are
the lifters?
Old 02-18-2015, 10:01 AM
akberkes's Avatar
Default camshaft
it has some scratches on it but nothing to bad just wondering if its normal or its shouldnt be like that
Old 02-18-2015, 10:12 AM
jcman's Avatar
Did you see the cam lobes or did the tech tell you this?
Old 02-18-2015, 10:43 AM
akberkes's Avatar
Yes i have just dont know when it should be changed
Old 02-18-2015, 02:14 PM
jcman's Avatar
It should be changed when the lifter is changed based on that you have said it's scored or potentially worn "lobes or lobe".
Old 02-19-2015, 08:32 AM
akberkes's Avatar
Thanks it will be changed we ordered the parts
Old 02-19-2015, 12:37 PM
jcman's Avatar
If you plan on keeping the car for a while its best to do it the right way once, those diesels have higher valve spring rates over gasoline engines so use good oil and change it a couple K-miles before its recommended.
canAudian
Audi allroad
06-21-2008 05:03 PM
dalgin
15
09-18-2007 06:25 AM
tinker6468
05-10-2006 04:53 PM
JLewis
02-11-2006 07:24 AM
2004-S4-340
07-08-2005 06:29 PM
Quick Reply: camshaft 2.5 tdi help
