Front impeller cv joint
#11
Ten minutes of searching
Try this link: http://www.vaglinks.com/Docs/Audi/C5..._CVBootDIY.pdf
Or: AudiWorld Tech Articles
And this one:https://www.audiworld.com/forums/a6-...2851936/page2/
The last one has a parts breakdown.
#13
SO let me get thios strait??
I can get a rebuilt axle for $40 to $60 each (Includes new boots and at least fresh grease on both ends)
Or I can spend $10 to $20 per boot ($20 to $40 an axle) and have to clean the old grease off, and hope the tear has not let in enough road grime to case issues???
#14
Re-boots are good if you caught it in a short time with no joint wear of course, yep even the chain AP stores sell them around $20.
#16
Drive shaft and axle shaft
Then you call a part a "hood" when 99% of us know that a hood is a body panel or somewere you live, if you called a drive shaft a drive shaft instead of a propeller/impeller then your question would of been very clear to most of us.
Hell blink my other spoken languge is German with a bit of Italian swear words and I'm still perplexed by your verbage, try searching drive-shaft instead.
#17
I did. The proper name is Propeller shaft. I call it that, or a drive shaft. I searched it, and found nothing on the particular issue that was of any use. I say hood instead of boot, but they are both the same. Like door cards instead of door panels, or my favorite, the boot instead of trunk. I contacted the manufacturer. The prop/drive shaft uses a retaining clip to fasten the end of the shaft to the cv. The grease came from the failure of the shop that pulled my tranny, not the gal but the gearbox, to use the supplied gasket on the end of the cv. Wholesaleimportparts is just going to warranty the whole unit. Now I have to build a jig, not the dance, the tool.
#18
Hope this helps and good luck!
