Coolant Temp Sensor Stuck. Ideas???
Old 05-14-2014, 11:47 AM
audia6q27's Avatar
Default Coolant Temp Sensor Stuck. Ideas???
2001 A6Q with 2.7T, 150K miles.
So, my temp gauge started showing cold when the engine is completely warm (94C as shown by VCDS) so I bought a new CTS to install.
Removed the clip (completely, have both pieces) and there is enough corrosion around the sensor to have "glued" the sensor into the water pipe. I'm at my wits end trying to figure out what to do.
Any tips on removing the old sensor? Pliers have not been any help. Heat, penetrating oil???
Old 05-14-2014, 12:09 PM
Tech Guru
4Driver4's Avatar
Use the pliers to twist, not pull. Once it is free it should come out.
Old 05-15-2014, 05:54 PM
Airbag's Avatar
also make sure that damn rubber seal isnt binding it up ...
Old 05-17-2014, 10:54 AM
georgeb944's Avatar
I just replaced one that was pretty well stuck in the coolant tube. Some tips from some local mechanics:
1) Make completely sure that the clip is removed. If you're not absolutely sure that it is out, there may be some broken pieces still keeping it in.
2) Remove the connector first, then soak the sensor perimeter with brake fluid or a bit of SeaFoam. That will help to deteriorate the O-ring.
3) Keep working, when you think it's not going to come, whoosh, there it is.
4) Use a needle-nose vise grips to get hold of the sensor at the point where the connector attaches. The green plastic is surprisingly strong.
Oh, make sure that you have extras of the clip when starting the job.
Reattach the connector before installing the sensor, push down until the sensor is fully seated, then reinstall the clip.
jbarrows82
01-30-2009 07:17 AM
eldoj
05-07-2007 09:55 AM
Greek_1.8TQ
10-11-2006 03:29 PM
marcogyver
Audi 100 / A6 (C4 Platform)
12-21-2004 02:40 PM
Arcteryx::Stock Rods
10-08-2004 05:17 AM
Quick Reply: Coolant Temp Sensor Stuck. Ideas???
