Last edit by: IB Advertising
- Audi A6 C6 Known Issues and Reliability<br>Important information to help you understand your Audi A6 C6.
How many miles can an Audi engine last?
#31
i think the original question is a bit ambiguous.
ANY engine can plast forever, it comes to how well its maintained and how many rebuilds you want to do . As long as you have an endless supply of engine parts and labour your engine will keep going. i think the real question is how long before it becomes economically unviable.
Lots of people give up when the cams go south on a 3 litre because the cars are worth so little now , in some cases to repair it or have someone else do it, is worth more than an engine .. or the whole car for that matter.
The 2.8 seems to just go forever , I have a had a few of the 2.8s and they truely just wear out . They are very robust but eventually the oil usage creeps up , and then it starts to affect the cats etc. It could easily be rebuilt with a a valve job, a new set of rings ,and maybe pistons and you are good to go .. is it economically viable ? probably not .. i replaced the whole car for a thousand dolllars.
probably in short it is evrything else that will wear out on your car that make it economically unviable before the engine..
#32
Agreed, but type of driving is incredibly important to an engines longevity. doing 100k in stop start traffic with an average speed of 10mph is going to wear an engine more than cruising at 80mph for 100k!
My 2.7t now has 184k miles and sings like a bird of paradise with the majority of its horses still alive and well under the bonnet. However it did need its first clutch last year at 170k miles....
Runs like a dream 25mpg combined driving. Am thinking time to do shocks!
#33
198k on my 2.8 A6 and 208k on my Chipped 1.8T A4. Neither use any oil between changes. Both are a little rattly in the morning but whisper quiet in a moment or two. I expect 300k out of both easily. The A6 used to use a ton of oil, until i cleaned out all of the snot from the breather pipes and it went to zero oil consumption. Good cars, don't let mileage scare you.
#35
1998 A-6 2.8L
I just retired my 1998 A-6 due to transmission failure. It had 364000 miles. I did all repairs after the initial 100,000 mile maintenance. Over the years I replaced an ECM, Starter, Cruise module, and window parts-- all considered normal wear and tear.
#36
My 3.0 is sitting in the garage with 185k needing a head gasket, add that to the $12k spent on repairs in the last two years and there is the reason I'm not fixing it. Already replaced the car, now I have to try to sell the A6 and get a little of my money back for the heap.
#37
#39
$12k for what?!?!
#40
Torque converter, servotronic steering rack, x2 full timing belt kits (water pump failed twice), brake caliper, and a bunch of smaller things that add up with parts and labor. A few $3k bills and others ranging from $80 to $900, USD.
