Moving Bose system (2001 A6)
(Cross posted from Audio section since no answers there)
What do I need to get out of a parts car to move the Bose system over to my non-Bose car?
Any tutorials on pulling the radio head and other parts?
You gonna need EVERYTHING! The wiring is different from the headunit out. I will say the bose system is overrated and your best bet is aftermarket if you want crisp clean sound.
Might be the subwoofer and amp(s) can go for a little dough. If you don't mind doing a little wiring, you can probably get the subwoofer working with an aftermarket headunit (and possibly a small external amp). Not sure if the work is worth the effort, but DIY'ing a subwoofer enclosure that efficiently uses the space behind the rear trim, is going to be one solid bastard of a job.
One notable mention is that the Bose speakers are 2ohm rated drivers and very few aftermarket radio amps can not handle a speaker below 4ohms, deck amps are a different story though.
The Bose amp is in the sub-woofer box mounted in the trunk, with this system the Symphony head is acting as a pre-amp but I believe Symphony I heads have amp capabilities vs. the Symphony II
I've never really handled one of the Bose subwoofers IRL - how is it construction-wise? would it hold up to some reasonably rated and approriately sized aftermarket woofer elements? Whith the right thickness and more importantly, cruving and profiling - plastic can be pretty stiff and sturdy.
If so, one might be able to put some decent 4 or 2x2ohm elements in the enclosure..? I've seen images of both single and dual woofer element designs - were there different ones or is it an Avant/Sedan design difference..?
I made my own out of file cabinet separators and I might have the drawing for it, but they are really cheap on fleabay or Amazon.
