009220 - EVAP Leak Detection Pump Sense Circuit: Implausible Signal
#81
As expected, after a week of testing by the top mechanic at Audi of Charlotte, they have determined that it is the ECU that needs to be replaced. The ECU would pass all the tests when it is cold, but when it heats up it gives the error code. I am having i replaced with an OEM ECU from Audi - $1,700. My rationale is A.) I already have $260 tied up in diag time that goes toward it B.) it's still cheaper than getting a new car.
If you do not hear from me, it's because I will have turned a new leaf with a CEL free dashboard.
#82
#83
#84
I have now driven three days in 94 degree weather and it has not come back on since they put in the new ECU. The service guy said he never wanted to see me again unless it was for service because they spent so much time diagnosing it. P2404 code no more - I actually remember the first time it came on in 2013. I am also getting much better gas mileage and it's running a lot smoother - or maybe it's just my imagination.
#85
#86
Thanks for the update. Hope that the new ECU resolves this problem for you. How many miles have you driven since it was replaced? The largest mileage interval for this DTC appearing on my '06 A6 Avant was a little over 700 miles. Now the DTC is appearing in less that 200 miles of driving. If possible, please provide updates as you add miles and if the P2404 PIA ever appears again.
#87
Here is what the report from Audi said:
ECM ISSUE SAME FAULT AS BEFORE. REMOVED LEFT REAR WHEEL AND FITTED TO LENGTH. FOUND VACUUM HOSE TO LDP PUMP HAD FOLDED OVER. REPAIRED AND FITTED TO LENGTH. RERAN TEST- DID NOT PASS. CHECKED WIRING AND FOUND RED AND BROWN T17 PIN CONNECTORS HAD CORRODED PINS. CLEANED, PUT STABILANT ON TERMINALS AND REFITTED. RAN TESTS- DID NOT PASS EXCEPT FOR ONE TIME WHEN COLD. WHEN VEHICLE HEATED THE TEST WOULD FAIL. REMOVED ECM AND PLACED INTO REFRIGERATOR AND LET SIT FOR 1/2 HOUR. TRIED AGAIN AND THE 71 TEST PASSED. ORDERED AND INSTALLED NEW ECM- CODED AND IMMOBILIZED. RAN TESTS SEVERAL TIMES -EACH TIME PASSED. RESET READINESS CODE- GOOD. ROAD TESTED-OPERATING TO MANUFACTURER'S STANDARDS.
I have also been getting up to 30.8 mpg on the highway and 24 mph in town which I have not seen in a long time.
#88
Thanks for the Audi report. The tech didn't ID the T17 pin connectors that were corroded in the report, but most likely the electrical wires to the LDP. I have run the 071 test numerous times and most of the time it passes ("System OK"). But sometimes, the test result was "ABORT". For my info, what year is you A6, how many miles on it, and what locale has it been in, e.g., marine, winter salt exposure, etc.? I am curious because this DTC initially appeared on my '06 A6 last year with ~73K miles on the car. The car has been garaged since I bought it 8 years ago, so I doubt I have any corrosion issues. I'm also looking into a weak battery (it still has the original battery!) issue that surfaced with the last CEL (DTC P1602 as well as infamous P2404). Will advise if I find anything.
#89
#90
Sadly, I have to bite the bullet too and have a brand new ECU installed. I have to smog the car and some of you may know, but Cali now does smog checks over OBD on newer cars, so it you have any DTCs or Readiness isn't completed, you're SOL.
Not happy about this...
