A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
HELP! Fault Codes!
Old 01-06-2018, 07:51 AM
RodriguesV's Avatar
Default HELP! Fault Codes!
Hi everyone,
my A6 4.2 2005 have some issues, and i scan with vcds and the result are some errors.
I just searched from some answers on the web, but i want to know if anyone had the same codes and possible solutions.
Sunday,31,December,2017,13:39:53:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: WAUDL74F15N089147 License Plate:
Mileage: 145250km-90254mi Repair Order: 000010
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 72 76
VIN: WAUDL74F15N089147 Mileage: 145250km-90254miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 560 F HW: 4F0 907 559
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number:
Coding: 0027772
Shop #: WSC 02335 785 00200
VCID: 254197B1EC30956A9A-8070
7 Faults Found:
29696 - No Communication with Comfort System Control Module (J393)
U1000 - 002 - - Intermittent
18965 - Ignition Switch; Run/Start Position Circuit
P2533 - 002 - Open or Short to Ground - Intermittent
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
16730 - Camshaft Position Sensor (G163)
P0346 - 004 - Implausible Signal - MIL ON
16725 - Camshaft Position Sensor (G40)
P0341 - 004 - Implausible Signal - MIL ON
18070 - Coolant Fan Control 2
P1662 - 002 - Short to Ground
Readiness: 0010 1001
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 G HW: 09L 927 156
Component: AG6 09L 4.2L5V RdW 0070
Revision: --H01--- Serial number: 0082036
Coding: 0001001
Shop #: WSC 04574 659 06332
VCID: 285F9E859B228802A1-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H05 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0021352
VCID: 2D516F91B4C0AD2A52-8078
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300100347
Coding: 0000007
Shop #: WSC 00197 659 10341
VCID: 63C5C9A9A2842B5AB4-8036
Subsystem 1 - Part No: 4F0 910 131 Q
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H25 0070
Subsystem 3 - Part No: 4F0 910 220 J
Component: FBSAUDIC6 IDG H01 0060
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory BFS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0070752
Shop #: WSC 04008 758 999999
VCID: 61C9C3A1B898394AA6-8034
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350LY047557365
Coding: 0000007
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000091513
Subsystem 3 - Serial number: 0109.12.040000000100010900ÿ
Subsystem 4 - Serial number: 010900ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000024 Serial number: 00000000098124
Coding: 0008264
VCID: 5BB5F1499AF4139AFC-800E
5 Faults Found:
00018 - Motor for Cold-Air Flap (V197)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00110011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 254
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:20
Freeze Frame:
Voltage: 14.30 V
Temperature: 22.0°C
(no units): 159.0
(no units): 119.0
Temperature: -40.0°C
00738 - Rear Heat Regulating Valve (N176)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 254
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:24
Freeze Frame:
Temperature: 89.0°C
00739 - Coolant Circulation Pump (V50)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:43
Freeze Frame:
Temperature: 89.0°C
01232 - A/C Compressor Regulator Valve (N280)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 254
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.30
Time: 11:52:00
Freeze Frame:
Load: 0.0 %
Current: 0.000 A
00737 - Left Heat Regulating Valve (N175)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 254
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.30
Time: 12:01:13
Freeze Frame:
Temperature: 79.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 A HW: 4F0 907 279 A
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0113101
VCID: 275D9DB9963C877AA8-8072
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
3 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 215
Mileage: 145252 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:00
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 215
Mileage: 145252 km
Time Indication: 0
Date: 2017.12.29
Time: 18:04:00
01494 - Bulb for Parking Lamps; Left (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 253
Mileage: 145252 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6040855
Shop #: WSC 00000 000 00000
VCID: 1C37B255DF7A54A235-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 32 AIRBAG AUDI8RH29 0250
Revision: 05H29000 Serial number: 0037LD052W2%
Coding: 0013106
Subsystem 1 - Serial number: 6332CSME084B3E607
Subsystem 2 - Serial number: 6342CSME084B437A9
Subsystem 3 - Serial number: 6351HSME057D461AD
Subsystem 4 - Serial number: 6361HSME055A01571
Subsystem 5 - Serial number: 6371VSME0528172FN
Subsystem 6 - Serial number: 6381VSME0535170EJ
1 Fault Found:
01590 - Igniter for Battery Disconnect (N253)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050070358
Coding: 0012141
VCID: 66C3D0BD51B65E7253-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 R
Component: KOMBIINSTR. M73 H10 0630
Revision: 00200000 Serial number: 4R6747GD4
Coding: 0065143
VCID: 1E33B85DC96646B2DB-804A
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 213
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:20
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804C160095
Coding: ECFE73DC1B0104
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H04 0050
Coding: 0066666
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: y)9
Coding: 0017130
VCID: 29599B818028B10ABE-807C
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01002173590000
Coding: 0402681
VCID: 2C5762958FDAA42245-8078
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: IRUE No Answer
7 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 215
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.07
Time: 18:03:55
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 4
Reset counter: 200
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.07
Time: 18:03:54
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 3
Fault Frequency: 209
Reset counter: 215
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:06
02071 - Local Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 181
Reset counter: 215
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:02:06
02735 - Bulb for Tail Light 3; Right
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 135
Reset counter: 214
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:06:44
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 80
Reset counter: 200
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.02
Time: 10:30:56
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 101
Reset counter: 214
Mileage: 145197 km
Time Indication: 0
Date: 2005.02.01
Time: 12:12:32
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000020068
Coding: 0000016
VCID: 264390BD91369E7293-8072
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000055084
Coding: 0011114
VCID: 5EB3F85D89E606B29B-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 9
Coding: 0017130
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0006021
Shop #: WSC 04565 659 97428
VCID: 5DB1FF5184E01DAA82-8008
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 02325 785 00200
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
1 Fault Found:
00496 - Sensor for Vehicle Leveling; Front
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 12
Reset counter: 0
Mileage: 145256 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:21
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352AQ057586147
Coding: 0000001
VCID: 316973E1A8F8C9CA76-8064
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000096168
VCID: 234589A9E2046B5AF4-8076
Subsystem 1 - Part No: 4F0 915 105 B
Component: von MLA 1897022MTM
Coding: 34463039313531303542204D4C41313839373032324D544D
Shop #: WSC 00230 695 91254
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0016426
VCID: 2A5B648D852EBA12B7-807E
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0016426
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 A HW: 4F0 919 283 A
Component: Parkhilfe 8-Kan H12 0030
Revision: --.--.-- Serial number: 11820434800419
Coding: 0001006
VCID: 224B8CADFD1E6252FF-8076
2 Faults Found:
01543 - Parking Aid Warning Chime (H15)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 214
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:19
01625 - Front Parking Aid Warning Chime (H22)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 145254 km
Time Indication: 0
Date: 2017.12.29
Time: 18:03:19
End-------------------------(Elapsed Time: 02:32)--------------------------
Old 01-06-2018, 08:21 AM
raj99's Avatar
Before replying to this please provide details as to exactly what's going on with your car and what seems to be the problem(s)
Sten M
05-19-2018 11:46 AM
changs4
10
11-17-2001 07:39 PM
Quick Reply: HELP! Fault Codes!
