C6 A6 Avant power tailgate, issues while closing
#21
Videos are showing how to save the position of the tailgate. Tried to repogram it to, programming seems to work but again, the tailgate won't open automatically unless I won't help it by raising it a littlebit.
I read about the motors which seems to be magnetic motors so basically there are no contacts which can give poor connection or something. I don't get it, why the door won't open itself. It might be that there are some connection problem somewhere else which is causing for example voltage drop so the motors aren't so powerful as they should be.
Good Luck!
#22
Just went through this with my 06 Avant and Audi. One Audi dealer replaced the struts. 2nd Audi dealer replaced the latch (which also has a sensor in it and may be the culprit with the hard drop - that's what the dealer told me). At that point, the only thing left was the motors. Bingo - problem fixed. Motors are $1200 and are replaced in a set. If your tailgate opens OK (mine would not - only open a couple of inches than shut again), I'd suspect the latch sensor which adjusts the motor speed to close the final few inches. I think that was under $300 installed.
Good Luck!
Good Luck!
Do you happen to have the part number for the latch?
#23
Latch was 126.20 parts 187.50 labor
And, I complained to the service manager that it shouldn't take 2 dealers, 2 diagnostic costs, shocks that didn't solve my problem, and latch that didn't solve my problem (no warranty) at my cost to properly diagnose the problem. He agreed and AUSA paid for the motors and reimbursed me for the latch and diagnosis.
Good Luck!
#24
Power tailgate stuck - any way to override?
Temps have been well below 0F and the power tailgate on my 2006 A6 is stuck all the way open. It's happened before in extreme cold but if I hit button a few times it would always close. Now it won't and I don't want to force it.
Is there any way to manually override the power so I don't have drive around with the thing wide open?
#25
DO NOT try jamming the tailgate shut if it's stuck open. Believe me, my father did it once and it ruined the motor, and it's not cheap. I have had the same problem with the inside button not always working, more so in the cold, and the first thing to try is shutting it with outside button above the plate holder. If that doesn't work it will sometimes randomly start working after awhile and pretending like you're somehow going to fix it. In my case it's only be completely stuck once when it was like -10f outside, and I had to take it inside to warm up before it would close.
No luck finding some sort of manual override. I know there is a TSB related to this issue somewhere. The Audi dealer has been no help to me, and the indie mechanic I take it to that's been extremely good couldn't duplicate and fix the problem either because it's so random.
As for the original video posted, that's how my gate always closes, but sometimes it does not open completely, or open at all when it's extremely cold...but I'm about sick of the gate issues! Only major annoyance I've had with this vehicle.
#26
Funny to see this today. Just dropped my '08 Avant off at the dealer ti fix the rear hatch.
It would close, but not catch completely. It would come out by about 1/8". Sometimes it would catch correctly, most times not.
I'll try to remember to post what the dealer comes back with tomorrow. It's still covered by the CPO.
Eric
Eric
reedjay
04-19-2000 09:17 PM
