Electronic Throttle Control Noise and hesitation on acceleration
On this video, I hear strange noise from the throttle area. This is after I changed the engine valve cover gasket due to leak. On assembly, I broke and repaired vacuum hose. I also took the time to clean the throttle body. I put it back together and had the vagcom throttle adaptation. No codes registering.
The car hesitates and jerks on acceleration and highway speeds. I suspected a vacuum leak but I don't see or notice any. Do I need a new Throttle body which is very expensive or any part like MAF. I do have a Vagcom on hand. Im open to any opinion thanks
A8 Throttle Valve fluttering
Hi, I'm new here, but not new to my A8. I also have vag and there are no throttle body codes. I did the procedure to calibrate, but did not help. My car is experiencing this same exact issue as the video shows below. It is repeatable when I give the pedal a quick rev to a couple thousand RPM and on the way back down, the throttle makes this fluttering action. I was hearing a flapping sound and started to look around the forum. I found this video although I have not taken mine apart yet to see it vibrate like this, the sound is exactly the same. I used my mechanics stethoscope and it's definitely coming from the throttle valve. Does anyone have an idea if I need to simply replace it or could this be caused by some other electronic or vacuum related issue?
Thank you!
Thank you!
Need your opinion on Audi A6 2005 3.2. Electronic throttle control making noise jerking on accelarat - YouTube
Audi A6 2005 3.2 L Quattro
tcwoods86
17
10-17-2021 11:01 AM
pr0xZen
04-09-2015 10:55 AM
PhunkFX
06-17-2007 06:06 PM
QuattroDrive
12-07-2005 01:43 PM
drive
08-26-2003 10:37 AM
