no autorization start no can bus comunication
hi i have problem with a6s c6 3.2 no can bus no autorization start nothing or cluster or vdo display cant release parking brake
we drive 150miles good we park at mall 20 later try to start no start battery low we remplace battery mmi configuration 10 to 15 min....later mmi say start the car now i try to start no start i try to pull out key no release the key i release pushing small bottom near of switch
maybe someone can help am sorry poor english
thanks
thanks
Your battery is no longer holding a charge. Replace the battery and make sure it's fully charged. Make sure the car is in "Park", turn the key off and on a few times to see if the key interlock disengages. These cars can do really weird thing if the battery voltage is even slightly low or the ground is bad.
hi ....i remplace the battery new from store nothing happend i will check the shifter microswitch and maybe try better grounds .....
why no can bus comunication ?
yes i write to edge motors they help me a lot nice support am far from edge motors they help me...
i try this ....
if i push start buttom the dash lights on and display say please park de vehicule but the shifter are park position....
if try to start no start y try conect 12v to the j518 and release the steering but wont start no autorization start ....
if push start buttom i hear pump gas rear working few secs or minutes...
i try this ....
Do you have access to a VCDS Vagcom tool? You can try this procedure:
https://www.youtube.com/watch?v=tNkNYqTrL3U
i try this ....
i try this ....
Could be a bad sensor on the transmission gear selector.
have u idea what sensor gear selector need check? why no canbus? audi mechanic come today and he say gateway bus interface 4F0907468D are bad i dont trust him ..................he works for audi shop he wants get a lot money from me
how can i know if this gateway need reprogram if buy second hand? 4F0907468D part number thanks
perlfather
03-27-2013 03:40 PM
