Replacing Centre Brake Light
rookie Audi owner here.
i own a 2011 A6. i got the "centre brake light" warning. i would like to see if i can replace this myself and avoid $$$$ at the dealership
did some brief research on the net and here and didnt really find much.
any help on where to buy a replacement (the right kind) and how to replace it?
thanks much
thanks much
thanks much
thanks much
Get the part number off your existing light and look on ebay.
Removing and installing inner rear light
Removing
– Remove rear lid trim.
Rear lid trim - exploded view
1 - Bolts, 1.8 Nm
q 2x
2 - Handle recess
q Removing and installing → Chapter
3 - Pop rivet
4 - Bracket for handle recess
5 - Spring clip
q Renew if damaged
6 - Rear lid trim
7 - Lock cover
8 - Operating mechanism for releasing rear lid manually
q Disengaging → Anchor
9 - Manual release for rear lid
q For USA vehicles and Audi A6 Security
10 - Cover for rear lid manual release handle
11 - Spring clip
q Renew if damaged
q Remove any clips left in body mounting points using -T40280-
12 - Bracket for warning triangle
Removing and installing handle recess
Removing
– Remove rear lid trim → Chapter.
– Remove speed nuts -arrows-.
– Take handle recess -1- out of trim.
Installing
Install in reverse order of removal; note the following:
– Insert handle recess -1- in rear lid trim.
– Position new speed nuts -3- on locating pins.
– Use hexagon socket (7 mm) -item 2- to press on speed nuts -arrow-.
– Install rear lid trim → Chapter.
Tightening torque
A70-10034
Component Nm
Handle recess to rear lid 1.8
– Unplug electrical connector -2-.
– Remove nut -4- and remove retainer bracket -3-.
– Detach inner tail light cluster -1- from rear lid -arrow-.
Installing
Installation is carried out in the reverse order; note the following:
Note
Ensure that seal between body and rear light housing seals correctly.
– Position inner tail light at outer edge of rear lid.
– Slide retainer bracket -1- onto threaded stud of inner tail light.
l Retainer bracket must engage in guides.
– Tighten nut -2-.
Note
As the nut is tightened the retainer bracket becomes wedged in the rear lid -arrows-.
Exploded view of inner rear light
1 - Inner rear light
2 - Retainer bracket
q Secures rear light to rear lid
3 - Nut
q 3.5 Nm
4 - Seal
q Renew if damaged
5 - Main connector
Removing
1 - Bolts, 1.8 Nm
q 2x
2 - Handle recess
3 - Pop rivet
5 - Spring clip
q Renew if damaged
6 - Rear lid trim
7 - Lock cover
11 - Spring clip
q Renew if damaged
Removing
Installing
Tightening torque
A70-10034
Component Nm
Installing
Note
– Tighten nut -2-.
Note
3 - Nut
q 3.5 Nm
4 - Seal
q Renew if damaged
5 - Main connector
