A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
UK: First Start in 7 years, diesel!
Old 04-07-2024, 01:47 PM
AudiManT's Avatar
Default UK: First Start in 7 years, diesel!
Trying to get my a6 avant started after 7 years! charged the battery up on a repair cycle only to fit it to the car and have no luck starting, the video attached is whilst being jumped by another 12v, any tips on whats wrong or am i going to have to bite the bullet and buy a new battery? (see attached)
Old 04-07-2024, 01:49 PM
KevinGary's Avatar
Did you drain the gas and replace with fresh?
Old 04-07-2024, 01:56 PM
AudiManT's Avatar
No i haven't yet, how would i go about draining the current diesel?
Old 04-07-2024, 02:24 PM
G-Can's Avatar
after 7 years, everything is seized and rusted, crank that engine by hand somehow first. Add some fresh oil, lubricate what can be lubricated, not just crank
not to mention old diesel
JohnnyJ (04-08-2024)
Old 04-07-2024, 02:37 PM
KevinGary's Avatar
After 7 years and old lubricants and fuel you are going to have your hands full. As G-Can said, you may want to crank the engine by hand first.
Old 04-07-2024, 09:50 PM
Sallad's Avatar
Did you watch the vid? It is clearly cranking over just fine, not "rusted". Just not firing.
I'd start with fresh fuel, fresh fluids and a fresh battery.
sswari (04-08-2024)
Old 04-08-2024, 12:04 AM
AudiManT's Avatar
Thank you Sallad mate! New battery on order, any idea how to drain the current diesel or can i just fill it up with fresh (currently has a 1/5 of a tank left)?
Old 04-08-2024, 07:33 AM
24V6BDW's Avatar
That clinking sound when trying to crank is a 100% sign that battery is gone. When you replace the battery, crank it and observe the exhaust in case of no start. If it's not firing up and there is no black smoke while cranking, inspect the fuel line/pressure first. Diagnose further, if needed.
Old 04-08-2024, 09:41 AM
sswari's Avatar
No, do not just add to the old fuel in the tank, you will have to figure out how to drain it.
Old 04-08-2024, 10:28 AM
jonzie77's Avatar
At least with the petrol version you can disconnect the fuel line under the hood and let the fuel pump do the rest into a can. I think the pump will continue to run on it's own because it will never achieve a pressure setting in the fuel delivery tubing. If that is not the case it should be easy enough to locate the fuel pump relay and jumper it out. I would think that any fuel remaining in the tank after this procedure would be sufficiently diluted by filling with new fuel, and probably include some fuel system cleaner as well.
Rambo2305
01-02-2017 04:33 AM
VONBOTTLE
02-21-2015 02:21 PM
Kevin White
16
01-21-2015 10:55 AM
laytex
11-13-2008 09:41 PM
SB-Audis
03-13-2003 04:11 AM
Quick Reply: UK: First Start in 7 years, diesel!
