Broken Pin in Hatch
Audi Enthusiast
Broken Pin in Hatch
So I stupidly left my umbrella half on the fixed 'trunk' cover and when I closed/opened the hatch, it broke one of the support pins on the hatch (2012 A7).
Wondering if anyone else has dealt with this before.
On this picture, it is listed as part 7, or "mount" along with the clip at 6:
When looking at online parts sources, it doesn't quite line up the same, but I'm thinking that it is part #21 on this diagram:
This is sold as piece of 'kit' 4G8-898-283-B-4PK which is illustrated like a 4-year old drew it (probably younger):
Still not too sure if that's the right bit. I've messaged one of the online sellers, so we'll see what they say...
The broken pin is rare but I remember it being the subject of a thread. I believe the solution was found at the Audi parts counter.
I found the thread I was thinking of but there was no real solution mentioned in it. There are a couple of alternate repair ideas stated.
https://www.audiworld.com/forums/a7-...cover-2895198/
I've managed to break them twice. Both times I just used a screw with a small enough head to fit in the "socket" until the dealer replaced them at a service - they (only one tends to break at a time) were replaced under warranty. The update model seems to be using a metal pin now, so that the new pin is stronger than the sensitivity level of the hatch closing mechanism, which the plastic pin was not.
Although the dealer replaced it with the same plastic pins both times, not the newer metal ones. Which amused me. Perhaps there is a different anchoring system for the metal pins?
Frankly, the screws worked just as well, and once in, you can't see them.
Audi Enthusiast
I found the thread I was thinking of but there was no real solution mentioned in it. There are a couple of alternate repair ideas stated. https://www.audiworld.com/forums/a7-...cover-2895198/
I did get a reply from one supplier that said it appeared the part I was looking at was the right one, so I might order it and see.
Thanks!
Audi Enthusiast
Zamora_Audi
07-06-2017 09:06 PM
owl
Audi 100 / A6 (C4 Platform)
11
05-17-2005 12:25 PM
DirtMonkey_NWB6S4
21
03-10-2003 10:40 PM
