Oil Leak from Pressure Switch or ???
My 1998 A8 Quattro is leaking oil like a sieve. The oil is coming down the oil filter housing. Is it possible for the oil pressure switch to leak this badly? Or is it more like a port from the oil cooler? Coolant levels are fine. No other apparent leaks.
I can't spot the leak without taking everything apart. Hoping someone knows of a common problem here.
is there oil any higher than that? mine is leaking from the cam seals on the front side of the engine. oil runs down between the timing cover backing plate and the block, down the head across the oil cooler.
I'm due for a TB service so I'll tackle it then.
prijedor
10-11-2009 04:10 PM
Evol
Audi 100 / A6 (C4 Platform)
11-19-2006 09:43 AM
in2audi
03-15-2003 12:01 PM
