Sponsored by:
Sponsored by:
2004 A8 D3 Powerflex Bushings
Old 11-10-2012, 07:08 AM
carniveau's Avatar
Default 2004 A8 D3 Powerflex Bushings
My understanding is that the D3 A8 uses the same bushings as the B5 A4 for the front control arms (upper and lower front and rear). Would that mean that the polyurethane bushings made by powerflex for the B5 A4 could be used on the D3 A8? I replaced the front control arm bushings on my previous car (2002 S60) with powerflex and loved them! The new car (2004 A8L) is in need of new control arm bushings and I would like to replace them with poly bushings. Any help or ideas would be appreciated. Thanks!
Old 11-10-2012, 12:39 PM
awdinut's Avatar
Default what did you notice to be different ?
I've never heard about them.
Old 11-12-2012, 06:41 AM
yrk2.7t@curbside's Avatar
Interesting...
Where did you hear that they are the same bushing?
That would be great if that is the case and mine are well getting crunchy.
Old 11-12-2012, 06:44 AM
Brozee's Avatar
I've checked other websites, a few said they are for the a4/a6/a8 and passat. If they are the same size I don't see why they wouldn't work. I don't have any experience whatsoever on this though. Would be nice to find a more durable replacement though.
Old 11-12-2012, 08:44 AM
mishar's Avatar
A4 and A8 have same upper arm bushings. Part number: 8D0 407 515 C.
Potential problem with polyurethane bushings is that usually they are not fused with inner and outer metal parts so they slide instead flexing rubber. That can create a huge noise. Usually they come with special grease to prevent that, but I am not sure how long it would work.
Old 11-12-2012, 09:01 PM
MP4.2+6.0's Avatar
Default Could be trial and error...
The origin of the basic aluminum suspension set up in the front of the D3 (putting aside the air spring) is part way through the D2 run when it was switched from steel to aluminum. In turn the design was borrowed from the A4 line 3 or 4 generations ago. I know of it since it also migrated to the A6 during the C5 run, first with the 4.2 in 2000.
From doing my C5 4.2, I think the arms and such are often model specific. It could be the bushings are more generic. Of course right there is likely exactly a/the weak spot of the design--Audi should not be using stuff from a set up back in an old A4 3,500 pound era (even that, a porker for its then size) and particularly with much lighter and smaller wheels and unsprung weights (think 15's and 16's and like 205's give or take ) and fitting the same size bushings on a car up well into the mid 4000 pound range with combined wheel and tire weights up to 50% heavier and similarly with meaningful larger disks and associated weights. Same issue I saw on the C5 where they really grew the mass and unsprung weights a lot over the years and with the various models but seemed to overlook the inevitable effect on the suspension bits.
Old 11-12-2012, 09:04 PM
bmwm750's Avatar
Poly bushing can be noisy if you don't keep them greased up, but if this is a direct fit, this could be a great way to get a more durable replacement for all of us.
Could be a blessing in disguise that Audi never re-engineered some of this stuff.
Old 11-14-2012, 09:09 AM
I'll be the guinea pig on this one.
I ordered a set yesterday, and they should be here tomorrow.
With any luck i'll be getting them installed this weekend...
I'll post back with my findings
Old 01-21-2013, 08:43 AM
mishar's Avatar
You promised.
Old 05-18-2013, 01:35 PM
Originally Posted by mishar
You promised.
Sorry for the late late late reply been out with some medical issues.
Please see my reply to Marks thread here https://www.audiworld.com/forums/sho...4&postcount=32
Quick Reply: 2004 A8 D3 Powerflex Bushings
