Sponsored by:
Sponsored by:
Air suspension troubleshooting and misc
Old 10-12-2014, 11:53 AM
SS_RTR's Avatar
Default Air suspension troubleshooting and misc
I've run VCDS on my '07 A8. The errors I'm getting are for Digital Radio(Sirius, which I don't plan to use), Rear parking brakes worn (still seem to work well), Left tail light (can't seem to clear, has an old freeze frame date and I can't visually confirm), TPMS sensors (will be replacing this week)
While I was in VCDS, I got some readings from the measuring blocks for the air suspension as the compressor comes on for 10-11 seconds every minute.
Given the readings below, should I try to calibrate or focus on a leak first (possibly front right)? Right front seems to be going down first, causing rear left to raise, at least that's what I interpret from the readings.
This was taken just as compressor started
Address 34: Level Control (4E0 910 553 J)
14:32:02 Group 004: Deviation from standard level
-4.0 mm Front Left
-7.0 mm Front Right
0.0 mm Rear Left
-3.0 mm Rear Right
This was taken just as compressor shut off
14:32:14 Group 004: Deviation from standard level
-2.0 mm Front Left
-2.0 mm Front Right
-1.0 mm Rear Left
-3.0 mm Rear Right
This was taken as compressor came on again
14:33:03 Group 004: Deviation from standard level
-4.0 mm Front Left
-7.0 mm Front Right
0.0 mm Rear Left
-3.0 mm Rear Right
Here are some additional measurements:
14:30:20 Group 005: Absolute vehicle height (mirror image of installation position)
103.0 Front Left
103.0 Front Right
111.0 Rear Left
102.0 Rear Right
Here is my full scan:
VCDS Version: Release 12.12.3 (x64)
Data version: 20140905
Sunday,12,October,2014,14:39:02:05558
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44E67N016150 Mileage: 140850km/87520miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: 71H21--- Serial number: AUX3Z0G0715209
Coding: 01060009190F0120
Shop #: WSC 00477 128 36639
VCID: 204FC585F3D6551EBBD-8075
No fault code found.
Readiness: 0010 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0030
Revision: --H01--- Serial number: 4285287
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2345CA89E2C04E06A6F-8076
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224BCF8DFDDA470EAD9-8077
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G0715209
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BF2D656B065DDE03D-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 2447C995E7CE493EDF5-8071
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348AR077509434
Coding: 0000003
Shop #: WSC 25167 444 53701
VCID: 33653AC95220DE8656F-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000030303
Subsystem 3 - Serial number: 0102.02.070000000100010051ÿ
Subsystem 4 - Serial number: 010051ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000113365
Coding: 0102865
VCID: 1C37F175DFBE71FE675-8049
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO31012007065A000000000233ÿ†89
Subsystem 5 - Serial number: 000233ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO01022007065A00000000
Subsystem 7 - Serial number: 65A000000000002ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0143123
VCID: 366303DD4152CBAE711-8063
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 000000
Shop #: WSC 131071 1023 08191
VCID: 2B5522A94A1086461EF-807E
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H14 4230
Revision: 91H14423 Serial number: 0037Q0G01HK4
Coding: 0532707
VCID: 2643D39D91F2BB2EC11-8073
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 3J5U1
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB4020AB9DBYÿ†63
Subsystem 5 - Serial number: AB9DBYÿ†63428RB4020AB8CDZÿ†63
Subsystem 6 - Serial number: AB8CDZÿ†63528RB4020AC542Fÿ†63
Subsystem 7 - Serial number: AC542Fÿ†63628RB4020AC594Nÿ†63
Subsystem 8 - Serial number: AC594Nÿ†63729RB401E57312Gÿ†63
Subsystem 9 - Serial number: 57312Gÿ†63829RB401E57365Pÿ
Subsystem 10 - Serial number: 57365Pÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: E5C114912C74F03688B-80B0
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3G1002672
Coding: 0048263
Shop #: WSC 44379 000 1048576
VCID: 2541D491ECF4B036C8B-8070
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0711781D7
Coding: F5F5DF7F707A0E
VCID: ECD761B5CF9EC17ED75-80B9
1 Fault Found:
02230 - Digital Radio (DAB) (R147)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 168
Mileage: 140854 km
Time Indication: 0
Date: 2014.10.12
Time: 14:18:42
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3150807
Shop #: WSC 00000 000 00000
VCID: 1A3BF76DD58A0FCE759-804F
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000050427
Coding: 0000000
VCID: E1C90081385C9C16743-80B4
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A5B27AD85EA9F4EE59-807F
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381BO077517371
Shop #: WSC 25167 444 54155
VCID: 387F0DE54B463DDE63D-806D
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000700800040
Coding: 0003479
VCID: 1D31FC71C4A478F690B-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040701290142
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 168
Mileage: 135342 km
Time Indication: 0
Date: 2014.02.13
Time: 17:19:47
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 D HW: 4E0 035 466
Component: BO_D3 H06 0320
Revision: 20S00002 Serial number: 01711060006821
Coding: 0000126
VCID: 275DDE9996F8A226FA7-8072
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 01112060004885
Subsystem 3 - Serial number: 0211.12.060000000100030052ÿ
Subsystem 4 - Serial number: 030052ÿ
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000104679
Coding: 0010111
VCID: 1E33FB7DC9A263EE891-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T197M05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 11.28 V
Count: 61
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2959D8A180EC9456EC3-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396BX077559071
Coding: 0000002
VCID: 316930C1A83CEC96243-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000000087
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 A0312COTUZ
Coding: 34453039313531303541205641304130333132434F54555A
Shop #: WSC 25170 444 53716
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700032840
Coding: 0232125
Shop #: WSC 25170 444 53832
VCID: DFCD06790E28AAE6427-808A
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 168
Mileage: 140854 km
Time Indication: 0
Date: 2014.10.12
Time: 14:15:47
Freeze Frame:
Speed: 0.0 km/h
Temperature: 26.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000701230095
Shop #: WSC 12336 024 394758
VCID: 346739D5572ED9BE4F5-8061
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7110I6
Coding: 1120503
VCID: DCB731751F3EB1FE275-8089
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730703110607
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H11 1130
Revision: 00000000 Serial number: 00000007535814
Coding: 0010900
VCID: 285FDDA59BE6AD5EF3D-807D
End ---------------------------------------------------------------------
Old 10-15-2014, 05:40 PM
SS_RTR's Avatar
Got an additional code today:
Wednesday,15,October,2014,19:10:25:05558
Control Module Part Number: 4E0 910 553 J HW: 4E0 907 553 F
Component and/or Version: LUFTFDR.-CDC H06 6310
Software Coding: 0015510
Work Shop Code: WSC 02313 785 00200
1 Fault Found:
01583 - Leak in System Detected
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 140980 km
Time Indication: 0
Date: 2014.10.15
Time: 08:08:23
Old 10-15-2014, 06:15 PM
mishar's Avatar
Most probably the front right has a leak. Check it with soapy water. Fix it right away or you will burn your compressor.
Old 10-24-2014, 05:42 PM
USAF_C17's Avatar
Mishar,
I have a similar issue. If the leak is found, can it be fixed(like an inner tube repair) or is a new/rebuilt unit in order?-Tony
Old 10-24-2014, 10:50 PM
mishar's Avatar
Unfortunately there is not. At least that I know about it. Some people claim that they fixed a leak with tire slime, but I would not recommend that. It may easily get into the system and clog it.
Old 10-25-2014, 09:42 AM
03_AR_CO's Avatar
sources for rebuilt air struts
Web Store
https://www.arnottindustries.com/par...74_gid701.html
I have used both companies for replacement air suspension parts, both very good, at less than half the price from dealership.
Old 10-26-2014, 01:35 PM
USAF_C17's Avatar
Thanks!
ohsigmachi
03-29-2016 05:04 AM
Junius
33
02-19-2016 08:06 AM
Pmpsch
Q7 MKII Discussion
14
12-06-2015 01:14 PM
DenverAudiQ7
Q7 MK 1 Discussion
10-01-2015 07:38 PM
cclsvtf
Q7 MK 1 Discussion
09-12-2015 01:06 PM
Quick Reply: Air suspension troubleshooting and misc
