AMI bridge cables
I've just fitted AMI into my 2004 D3, as I am in the UK I used this 3rd party cable set from eBay.
AUDI MMI 2G A4 A5 A6 A8 Q5 Q7 FIBRE OPTIC PLUG & PLAY HARNESS WIRING | eBay
The original Audi kit is £79 here in the UK, and also on eBay.
CD changer retro fit wiring loom Audi A4 A6 A8 Q5 Q7 4F0051592A New genuine Audi | eBay
One thing to note if you want to keep the changer and you want VCDS to continue to work correctly, you need to modify the power loom and insert a loop between pin 1 and 4 on the AMI side to initialise the Mediaplayer2 position. If you do not do this, the AMI will work perfectly, but a VCDS connection to Mediaplayer 1 will show it alternating between the AMI and CD Changer. If you look at the video in the post below, you can see VCDS Alternating.
A8 Parts Forum - View Single Post - AMI retrofit / MMI update. Without the loop you'll also get a module not correctly on the can gateway, and you cannot scan mediaplayer 2 at all.
The official Audi kit comes with the cable wired correctly, it is pot luck on the 3rd party kits if the pins are wired correctly.
CD Player for MMI upgrade
However, just make sure to upgrade your MMI, if needed, prior to losing the CD player. In North America, 4610 is most recent, but minimally you need 3360 for AMI support.
landjb4u
24
04-18-2009 12:18 PM
killer whale
10-31-2006 03:14 AM
TabulaRasa
06-05-2003 09:25 PM
