Sponsored by:
Sponsored by:
4.2 BFM Start problem
Old 03-22-2015, 03:02 AM
Kiter's Avatar
Default 4.2 BFM Start problem
A winter start without problems and heat only where it is only 60 ° C long 4s starts about what it might be? VCDS no fault ..
Old 03-22-2015, 06:36 AM
Mister Bally's Avatar
I started a thread here regarding a no start problem 3 or 4 years ago. I recall mentioning that I noticed long start times just prior to being stranded. Once the no start happened, vcds pointed me right to the bad part. I and others have commented to several other posts with the same symptoms.
Hint: on most VW and Audi engines produced in the past 20 years (engines with coil packs, not distributors for the ignition system), there is exactly ONE sensor that, if failed, will cause a no-start condition. All other engine sensor failures will cause poor running conditions, but the engine will run.
Old 03-22-2015, 07:44 AM
mishar's Avatar
And the answer is: Engine Speed Sensor!
It is bolted from below into front of transmission, flywheel area.
Old 03-22-2015, 10:41 AM
Kiter's Avatar
Thank you. I'll try to replace it I hope it will help
Old 11-04-2015, 07:30 PM
Greybeast's Avatar
Would you possibly have a part number for that sensor?
Thanks, Mike
Old 11-05-2015, 03:08 AM
Jack88's Avatar
077905381J
I think that's what you are looking for.
Old 11-05-2015, 03:28 AM
Greybeast's Avatar
Thanks Jack!
Old 11-05-2015, 05:18 AM
Jack88's Avatar
Keep in mind, that's for the car in your signature. The 4.2 BFM is a different motor, and could have a different part. I hope that does the trick!
Old 11-05-2015, 06:04 AM
Greybeast's Avatar
Thanks Jack, That part will be for the car in my sig. Btw, did you run across a decent write-up on replacing that part?
Old 11-05-2015, 06:46 AM
Petahs's Avatar
It's not too bad check this thread for procedure.
https://www.audiworld.com/forums/a8-...2875669/page2/
Quick Reply: 4.2 BFM Start problem
