disconnect battery overnight--now variant rpm...
#11
It really sounds like a module lost it's memory and now needs to re-learn it's settings.
It could also be that a module just didn't initialize correctly. I would disconnect the battery, touch the battery cables together to remove any residual charge, wait 5 minutes, then reconnect the battery.
been reading a lot about dangers of disconnecting battery.
seems things do have to relearn and can take up to 100 miles to do so is various driving conditions. I have not done this many miles yet
#12
However they are never going to relearn properly with existing issues still unresolved.
Did you notice my post with all the manuals for download, i recommend you save them and get acquainted.
#13
I did see your manuals. Thank you.
#14
I think you need to have a good read through these and get an understanding of the various systems to then go fault find properly.
Electrical General
#17
It was getting late for me yesterday and I never thought to look at your vcds scan.
The engine code i was asking about is BFM
BFM Manual
Electrical
Gearbox
Brakes
Communications
Electrical General
Electrical Systems
Fuel Supply
Fuel Supply
Maintenance
Ingnition System
Service Gearbox
A8 Technical Features
09E Gearbox Part 1
09E Gearbox Part 2
BFM Manual
Electrical
Gearbox
Brakes
Communications
Electrical General
Electrical Systems
Fuel Supply
Fuel Supply
Maintenance
Ingnition System
Service Gearbox
09E Gearbox Part 1
09E Gearbox Part 2
otherwise it's just too coincidental that the herky-jerky driving came along only after I reconnected battery.
I did readapt the TB after the battery was disconnected but that didnt seem to help.
Now some have suggested torque converter failing, or atf low--which yes are possible causes.
but i'm thinking first point to start is whole air intake, maf, idle control valve, plugs and coils...
