Sponsored by:
Sponsored by:
help with lower valve cover gasket info V10 S8
Old 02-27-2017, 07:22 AM
mrduramax's Avatar
Default help with lower valve cover gasket info V10 S8
I've been searching for hours I need more info on the lower valve cover gasket which is called something like cam cradle
Old 02-27-2017, 07:34 AM
haggisuk's Avatar
Which item
Old 02-27-2017, 07:59 AM
Giovanni Giovino 6.0+6.0TT's Avatar
The cam girdle uses a sealant between the bottom of girdle and top of head, so item # 35 or 36, tubes shown in diagram.
Like this sealant in the link, BUT be sure which sealant is for your specific V10 engine, call the dealer for the proper item.
https://shopdap.com/store/d-154-103-a1.html
Last edited by Giovanni Giovino 6.0+6.0TT; 02-27-2017 at 08:08 AM. Reason: add info and link
Old 02-27-2017, 08:46 AM
haggisuk's Avatar
The sealant mentioned in the parts list is D 176501A1
Old 02-27-2017, 09:39 AM
mrduramax's Avatar
I need to change number 13 on both sides so whatever Parts and diagram needed would be great
Old 02-27-2017, 10:59 AM
I take you are looking for numbers 13 and 14 as shown in the upper diagram as previously posted, may I ask why you are not calling the dealership for these ?
Attached Thumbnails help with lower valve cover gasket info V10 S8-20170227_145406.png   help with lower valve cover gasket info V10 S8-20170227_145439.png
haggisuk's Avatar
File Type: pdf
Old 02-27-2017, 11:02 AM
Also just a FYI, the "Cam Cradle" is not a gasket, it is an aluminum girdle to hold the intake and exhaust cams in place...
Old 02-27-2017, 11:58 AM
mrduramax's Avatar
thanks hagg
Old 02-27-2017, 04:06 PM
mrduramax's Avatar
if I can get some info on the Medtronic megatronix whatever it's called the valve body that would be great I am there now
Quick Reply: help with lower valve cover gasket info V10 S8
