MMI Screen Repair Instructions
#12
Loose on the shaft or meshing the other gear? Check if your motor set completely before you tightened it with screws. There are small centering pins around two front screws.
#16
Once the big gear is installed nothing should be able to move independently correct? The cover, arm(all the way up in photo), and holder should be linked?
On mine I can still move the arm that is visible on the side separately. It does not go back to the position I set it in before I installed the big gear.....
Thoughts?
Thoughts?
#18
Got it! I don't know why I had so much trouble with this. I had to screw the screen on before putting the big gear in. The arm moves a little bit before the screen holder is out of the locked position. Thanks for everyone's help.
#19
mishar:
Did you get my email from last week? Just the other day, I had the first issue with my screen (2006 A8L). When I turned on the car, the screen did not pop up all the way. Tried manually opening/closing it a few times, nothing…but was able to coax it out gently and then stayed up for the ride. Turned off/on the car a couple of times, and once the screen would not go down all the way...just sort of froze 1/2 way.
It's been ok a few more times since then, but I'm guessing this is an indicator of what's to come. It also seems to have a very small "hiccup" about 1/2 way through the open/close process (barely perceptible) which I'm wondering if it is due to broken or missing teeth/tooth on the gear. And may explain the above screen getting hung up. Does that seem right?
My question - is this a gear related issue? If so, mark me down for a set of the gears and let me know how much payment to send and I'll get it out ASAP.
#20
mishar:
