Motorized rear blind
#74
Use 1/8 pop rivets. 1/8 washers to prevent pooling rivets into plastic. Add a very tin piece of metal between aluminum and plastc so when you remove it clip is free to rotate.
#75
OK..i'm fairly handy fixing things, but i just cannot figure out how to get this fixed. The metal arms open and close fine, but i cannot get any movement once they are fully open or closed.
This creates an issue when trying to get everything aligned for a pop rivet.
Can someone provide more detailed steps?
I have the kit from Nathan, but unsure exactly how to go about this.
#77
#78
Thank you for the instructions...they are helpful.
One remaining issue...how do I get the arms to stop mid-swipe? I tried with door open/closed...using key and keyless. No matter what I try, the arms continue to move to full close or open.
#79
AudiWorld Wiseguy
Anyone figured out what the root cause of the clips breaking is? What causes the over stress? Is it the clips wearing out slightly allowing them to bind in the track? Would some sort of lubrication help?
#80
Have you tried dedicatet button
