Sponsored by:
Sponsored by:
Need vacuum hose diagram
Old 06-04-2010, 06:03 PM
tashakes's Avatar
Default Need vacuum hose diagram
I am in need of the diagram that shows how the vacuum reservoirs are connected to each other. If someone here has it, I will forever be grateful
Cheers
Edward
Old 06-06-2010, 06:39 AM
MP4.2+6.0's Avatar
Default Look right there on underside of the hood
Audi puts the vacuum diagram on a sticker. If it's not there, hood was likely replaced/repainted.
Old 06-07-2010, 07:27 PM
tashakes's Avatar
Thanks, I found it.
The diagram show both reservoirs connected to each other and then it goes to the main line that feeds from the intake manifold on the front of the engine, there is a T hose connector that is broken and the hose missing, so one of the reservoirs is connected and the other is not. The T hose connector broke and the white connector on the reservoir too, so I assume a small hose is missing. I purcahsed the car as an incomplete repair because they were not able to finish the repairs on a timely manner, and this is one of the details I need to finish. ELSAWin shows absolutely nothing on the vacuum system.....
Cheers
Old 07-10-2019, 12:31 PM
maxandtara's Avatar
Default Modified Diagram
I finally figured out those vacuum lines. I hope this helps the next guy.3mm vacuum lines front.pdf3mm vacuum lines rear.pdf
Old 07-16-2019, 03:45 PM
maxandtara's Avatar
Default vacuum line
vacuum lines front
Rear vacuum hoses
The following 4 users liked this post by maxandtara:
dieselsanddust (07-20-2019), Mister Bally (05-19-2020), RNtoNP (09-28-2022), target39 (09-14-2019)
tenaciousd
08-23-2007 02:03 PM
simonyun
11
07-28-2007 07:48 PM
Thor67
03-08-2006 07:27 PM
olde_fortran
08-03-2004 06:12 AM
CGTCOMM86
05-30-2002 02:22 AM
Quick Reply: Need vacuum hose diagram
