Ok the on going saga with my fuel issue ......
when my tank drops to 1/4 of gas tank. I think everyone knows by now, but while driving or just at idle, if my gas tank has about a 1/4 of a tank the car just shuts off. It will start back up and I can continue to drive. So anyway I found some extra cash to have the only European mechanic in my area to look at it. He told me my fuel pumps I have installed about 8 months ago were not installed correctly. So 200.00 later he said it should be fixed. Well it is not fixed and now I get this new DTC I have never received before.
16839 - EVAP System
P0455 - 001 - Large Leak Detected
Needless to say I have a call into them. Also I ran some output test and have attached results. Everything passed except Fuel Leak. I know the Fuel Leak was never there before. Any Ideas?
16839 - EVAP System
EVAP deals w/ vented fumes of course, so logically connected to the work. Probably loose or unconnected hose or something like that. Assuming the tank was closed/sealed back up properly that is...
It doesn't matter what gurus up here suggest
If you don't do the work yourself, it's time to dump the car, one incompetent surgeon after another, your car is totally wounded without history. Until you find out what makes the car shutoff at idle? Fuel leaks, do you smell the gas? If not, then sensor and wiring. Get the manual, disassemble the whole gas tank and start from scratch, do it right and you may see broken wires, unplugged sensors, broken or out of place seals, screws or washers are loose or missing, floats got kinked due to installing incorrectly... Best is to understand the fuel pumps and gas tank systems. Any monkey with a wrench can remove anything in your car, putting it back correctly needs brains and care, and god knows some knowledge and integrity.
Cheers and good luck,
Louis
Louis
16839 - EVAP System
16839 - EVAP System
16839 - EVAP System
16839 - EVAP System
Another thing would be maybe your fuel level probe wasnt installed correctly. Its attached to the RH pump if I remember correctly.
It is EVAP system leak. Not fuel leak. It shouldn't be a big problem to find it. Back to that last mechanic.
By the way, is it still stalling at 1/4? You also never said that it restarts and drive after stalling.
It does restart after stalling
And yes it still does stall at about 1/4 of tank. Sorry if I did not mention that earlier. I do have a call into the last mechanic. Not only did it not get fixed I get the a DTC code that I have never received before. Bummer
eurovan5150
Audi 100 / A6 (C4 Platform)
01-31-2006 08:58 AM
changs4
10-30-2005 07:41 PM
