Sponsored by:
Sponsored by:
Will these wheels fit?
Old 08-08-2014, 07:01 AM
CMS062407's Avatar
Default Will these wheels fit?
Hello alll,
I found a set of 2014 Audi A8 wheels on craigslist and I am curious how they would fit on my 2007 A8L?? Has anyone else put these wheels on?? Thanks a lot. Look below for link.
Audi Speedline Wheels (S7 S8 A7 A8 S5 A5)
Old 08-08-2014, 07:54 AM
Former Vendor
AutohausAZ-Mike's Avatar
Here is a cool site for wheel specs:
Bolt pattern | Stud Pattern : Bolt Pattern list 5 X 112
Old 08-08-2014, 08:23 AM
CMS062407's Avatar
That website doesnt show 2014 models.
Old 08-08-2014, 09:08 AM
mishar's Avatar
They will fit perfectly. Outside diameter is a bit larger so your speedometer will show 4% lower speed than now, but that could actually be closer to the real speed. You will have a bit less gap between tires and fenders and that looks better. If the rims are not scratched and tires really have only that much on, it is a real bargain. Go for it before it is too late.
Edit: You will need hubcentric rings because the centerbore on a newer models is larger than on your A8. They are cheap and easy to find.
Old 08-08-2014, 09:14 AM
Former Vendor
Its the same bolt pattern
Old 08-08-2014, 09:23 AM
mishar's Avatar
2007 A8 57.1 mm
2014 A8 66.56 mm
Bolt pattern is the same 5x112 mm
http://www.ebay.com/itm/4-Aluminum-HUB-CENTRIC-HUBCENTRIC-RING-RINGS-66-56mm-to-57-1mm-/231197235256?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d46dd838&vxp=mtr
Old 08-25-2014, 07:08 PM
CMS062407's Avatar
Originally Posted by mishar
2007 A8 57.1 mm
2014 A8 66.56 mm
I ended up getting the wheels and tires for 900. Seemed like a steal!!
dmlevel.com
10-24-2007 01:17 PM
xr8edS4
Wheels & Tires Discussion
12-21-2002 07:36 AM
EricPA
02-07-2002 03:58 PM
got_root?
11-30-2001 08:26 AM
got_root?
11-30-2001 07:35 AM
Quick Reply: Will these wheels fit?
