Real time help, stuck at work.
#22
Main crank sensor = crank position sensor?
Can you link me or send part number so I can do some research tonight? Thanks
Quick look on ECS parts showed no results
#24
Two parts found, both listed as D3 parts. One is the sensor only, one has a harness bit and long wire attached. Anyone know which the 2006 uses? I can't crawl under my car right now, it's 55 mins away!
#25
I dont have a 4.2 so would not know #'s or exact configuration.
#26
Just spitballing here but I don't think the crank position sensor prevents the moving of the shift lever, so I would again check the status of the brake switches when you have a no start problem present with Vcds
#27
OP,
When you say "no start", what exactly does it do, does it crank over but no fire up, or does it not crank at all ?
#28
Ok, anwering your question first.
By "no start" I mean that all the electrical comes on, but the engine doesn't even try to turn over. I get MMI, climate, cluster, everything gets power, but it doesn't even click when I turn the key to start position. Push button yields the same result.
#29
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E96N019693 Mileage: 175720km-109187miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0F0784333
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E534587B98F923202-807A
2 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 59
Reset counter: 255
Mileage: 162484 km
Time Indication: 0
Freeze Frame:
RPM: 803 /min
Load: 70.6 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 28.0°C
Absolute Pres.: 0.0 mbar
Voltage: 11.176 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 22.0°C
Voltage: 11.938 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0077174
Coding: 0000002
VCID: 2541BAABEC79D16AF3-8070
2 Faults Found:
049412 - No Communication with Cruise Control Module
U0104 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 37
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:55
Freeze Frame:
RPM: 0 /min
RPM: 1056 /min
RPM: 1536 /min
(no units): 38.0
(no units): 25.0
Temperature: 48.0°C
T.B. Angle: 0.0°
062245 - Unknown Error Code
U3325 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 38
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:56
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224BA1B7FD57265296-8076
4 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication
01299 - Diagnostic Interface for Data Bus (J533)
01315 - Transmission Control Module
02083 - Message for Delay Request
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F0784333
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFC35FEB8BBC82B8-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00576 - Terminal 15
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 175296 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:54
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
VCID: 2447A7AFE7432862E4-8070
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 346AP067530666
Coding: 0000003
VCID: 204FABBFF35B344280-8074
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000057090
Subsystem 3 - Serial number: 0131.01.080000000100010117˙
Subsystem 4 - Serial number: 010117˙
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:15:20
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000090194
Coding: 0004417
Shop #: WSC 22198 444 64035
VCID: 1C379F4FDF3310A25C-8048
2 Faults Found:
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 13
Reset counter: 242
Mileage: 171327 km
Time Indication: 0
Date: 2016.06.09
Time: 16:21:28
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 242
Mileage: 171327 km
Time Indication: 0
Date: 2016.06.09
Time: 16:21:28
Freeze Frame:
Temperature: 39.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 36636DE741DFAAF24A-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Time Indication: 0
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7266809
Shop #: WSC 00000 000 00000
VCID: 1B359C53DA3D179A55-804E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Component: SDAR
Serial number: AUZ4Z7E2019409
VCID: 2643BDA7917FDA72FA-8072
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 198
Mileage: 175288 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 075
Raw, Form. N/A: 000 000 000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0004NYB
Coding: 0532707
Shop #: WSC 22198 444 84161
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36FGA
Subsystem 3 - Serial number: 0001.01.0000H0100000000000˙†63
Subsystem 4 - Serial number: 000000˙†63328RB400E1D413E˙†63
Subsystem 5 - Serial number: 1D413E˙†63428RB400E1D46DU˙†63
Subsystem 6 - Serial number: 1D46DU˙†63528RB400E1D8CB$˙†63
Subsystem 7 - Serial number: 1D8CB$˙†63628RB400E1D892S˙†63
Subsystem 8 - Serial number: 1D892S˙†63729RB400D76155K˙†63
Subsystem 9 - Serial number: 76155K˙†63829RB400D761B0M˙
Subsystem 10 - Serial number: 761B0M˙
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 65C1FAABACF9116A33-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F0003789
Coding: 0048203
Shop #: WSC 46297 000 104857
VCID: 326B51F7ADB7B6D266-8066
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.09.01
Time: 07:39:26
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 20003061228034
Coding: FCFE7BDD1B7904
VCID: 275DB0A39675C37AC1-8072
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 175296 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:54
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0010210
VCID: 285FB39F9B6BCC02C8-807C
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355BX067561786
VCID: 387F63DF4BCB5C8258-806C
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:20
Freeze Frame:
Bin. Bits: 1100
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H03 0090
Serial number: 00000532200021
Coding: 0003477
VCID: 1D31924BC42919AAAB-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601160028
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
5 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 243
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:56
01366 - Opened Due to Crash Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 243
Mileage: 175311 km
Time Indication: 0
Date: 2016.08.29
Time: 06:00:00
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 203
Mileage: 131072 km
Time Indication: 0
Date: 2014.08.10
Time: 11:59:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:20
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000006062
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:18
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000078354
Coding: 0010111
VCID: 1E339547C92F02B2B2-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T13BT05
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 243
Mileage: 175308 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 46297 000 1048576
5 Faults Found:
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 239
Mileage: 175304 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:58
Freeze Frame:
Voltage: 12.84 V
Count: 244
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 243
Time Indication: 0
Freeze Frame:
Voltage: 11.08 V
Count: 246
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 243
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 247
00576 - Terminal 15
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 4
Fault Frequency: 3
Reset counter: 203
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 41
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 243
Time Indication: 0
Freeze Frame:
Voltage: 10.87 V
Count: 243
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396AR067531923
Coding: 0000002
VCID: 2345A4B3E24D2F5A9D-8076
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 175507 km
Time Indication: 0
Date: 2016.08.30
Time: 06:33:28
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000000629
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 310212C07X
Coding: 344530393135313035412056413033313032313243303758
Shop #: WSC 22198 444 05017
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:21
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700037458
Coding: 0232125
VCID: 5FCDE8438EA54BBAF9-800A
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000601130281
Shop #: WSC 12336 024 394758
VCID: 2D51428BB489E92A3B-8078
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720602003332
Coding: 0201208
5 Faults Found:
01549 - Supply Voltage for Parking-Aid Sensor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:59
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 243
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:57
Freeze Frame:
Fault Priority: 4
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:59
Freeze Frame:
Fault Priority: 4
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:59
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 243
Mileage: 175311 km
Time Indication: 0
Date: 2016.08.29
Time: 06:00:05
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007529115
Coding: 0010900
End-------------------------(Elapsed Time: 03:49)--------------------------
Coding: 0007773
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 59
Reset counter: 255
Mileage: 162484 km
Time Indication: 0
Freeze Frame:
RPM: 803 /min
Load: 70.6 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 28.0°C
Voltage: 11.176 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 22.0°C
Voltage: 11.938 V
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 37
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:55
Freeze Frame:
RPM: 0 /min
RPM: 1056 /min
RPM: 1536 /min
(no units): 38.0
(no units): 25.0
Temperature: 48.0°C
T.B. Angle: 0.0°
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 38
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:56
Coding: 0007597
4 Faults Found:
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 175296 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:54
Coding: 4071520
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:15:20
Coding: 0004417
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 242
Mileage: 171327 km
Time Indication: 0
Date: 2016.06.09
Time: 16:21:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 242
Mileage: 171327 km
Time Indication: 0
Date: 2016.06.09
Time: 16:21:28
Freeze Frame:
Temperature: 39.0°C
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Time Indication: 0
Component: SDAR
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 198
Mileage: 175288 km
Time Indication: 0
Freeze Frame:
Coding: 0532707
Coding: 0012141
Coding: 0048203
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.09.01
Time: 07:39:26
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 175296 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:54
Coding: 0010210
Coding: 4071530
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:20
Freeze Frame:
Bin. Bits: 1100
Coding: 0003477
Coding: 0032364
Coding: 0048702
5 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 243
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 243
Mileage: 175311 km
Time Indication: 0
Date: 2016.08.29
Time: 06:00:00
Freeze Frame:
Fault Priority: 3
Reset counter: 203
Mileage: 131072 km
Time Indication: 0
Date: 2014.08.10
Time: 11:59:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:20
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:18
Coding: 0010111
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 243
Mileage: 175308 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:00
Coding: 0032364
Revision: --H03---
Coding: 0000532
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 239
Mileage: 175304 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:58
Freeze Frame:
Voltage: 12.84 V
Count: 244
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 243
Time Indication: 0
Freeze Frame:
Voltage: 11.08 V
Count: 246
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 243
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 247
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 203
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 41
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 243
Time Indication: 0
Freeze Frame:
Voltage: 10.87 V
Count: 243
Coding: 0000018
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 175507 km
Time Indication: 0
Date: 2016.08.30
Time: 06:33:28
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 243
Mileage: 175653 km
Time Indication: 0
Date: 2016.08.31
Time: 17:06:21
Coding: 0032364
Coding: 0232125
Coding: 0032364
Coding: 0201208
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:59
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 243
Mileage: 175310 km
Time Indication: 0
Date: 2016.08.29
Time: 05:59:57
Freeze Frame:
Fault Priority: 4
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:59
Freeze Frame:
Fault Priority: 4
Fault Frequency: 24
Reset counter: 243
Mileage: 175288 km
Time Indication: 0
Date: 2016.08.29
Time: 05:41:59
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 243
Mileage: 175311 km
Time Indication: 0
Date: 2016.08.29
Time: 06:00:05
Coding: 0010900
