Remote key cosmetic refurb.
I always use the same key remote of the set I have, and started from the more worn one when I got the car 6 years ago. Over the years it has gotten beat up.
Recently the little four ring logo fell off the back. Initially I was disappointed, though I found you can get the logos on eBay. But, it started me on a different idea when I looked at the listings--just buy a whole replacement remote and swap out the important guts that personalize it to my A8--the circuit board and the cut key. On eBay you can find Asian knock offs of the key case that look pretty good. But then for a few more $$--exactly $20 and $5 shipping--I bought a complete key that cosmetically looked excellent. I knew the electronics and cut key were essentially useless, so I was going for the keypad, panic button and case appearance, plus the now missing logo on mine.
The logo falling off is what clued me in. The hidden screw that really holds it together is...under that logo. I won't write a whole "how to" here, but it took about 20 minutes total. Half was for the mechanical roll pin for the physical cut key, which I have done before on old remotes before electronic interlocks came in circa 2001. The other 10 minutes was for the guts. I took my old one apart just to get a feel for the construction. Now knowing that, I realized it has the classic popping clock spring type set up for the switchblade function. So during the "transplant" part for my pre existing circuit board I just held the switchblade in place (on the side with the release button), and pulled the purchased donor case apart. With that I simply put the circuit board from my old key into it, screwed it back together, applied the logo that I had carefully pried off the same key, and it was done. Tested w/ car, and all great.
The picture shows the eBay donor key just before I transplanted the parts from my fully dissasembled old key beside it. When I did the swap over only the screws, the battery and circuit board were fully taken out and the rest of the bit parts seen in the picture around the switchblade area stayed together in the "new" body.
I used this: http://www.ebay.com/itm/Uncut-Folding-Flip-Remote-FOB-Key-Case-Shell-for-Audi-3-Buttons-panic-3BT-/121176613851?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAudi%7CModel%3AA8&hash=item1c36b063db&vxp=mtr
I found fob case on eBay. It was cheep and acceptable quality. It has to look exactly like the original. Otherwise you can't transfer electronics to it.
cautionary tale...
I used this: ___
The Chinese key only looked like a Bentley key...everything about its dimensions and construction was incompatible with my Audi circuit board. Useless. So I ordred the Audi version and the one I got was usless also. Bought another OEM Bentley key on eBay and swapped out my circuit board, transferd the keyblade/flip mechanism and I now have a new 'monogramed' key.
So you are fortunate to have gotten a knock-off that is actually a useable clone of the real-deal Audi key. Anyone who wants to use Chinese copy should buy from the seller that you bouight from I would say.
has anyone tried this one?
KeyMam LockSmith Shop | http://www.KeyMam.com-Audi 3 button flip remote key shell
