Sponsored by:
Sponsored by:
something odd with function of parking brake
Old 09-30-2014, 09:54 PM
awdinut's Avatar
Default something odd with function of parking brake
The parking brake will set, but the motor runs much longer than is normal. Same with the release, and all this started today. Anyone else ever experience this ?
Old 10-01-2014, 02:09 PM
mcs
mcs's Avatar
Mine can do this about once every month or so for only the 'applying the brake' part. I believe this is because it is calibrating for pad wear. Once done, it doesn't do it again for a while.
Mike
Old 10-01-2014, 05:48 PM
awdinut's Avatar
Default this is not a calibration
Mike
yes, they do calibrate the system from time to time, but that is not whats going on with mine. This behavior occurs everytime , and the e brake motor doesnt run nearly as long as during a calibration.
Old 10-01-2014, 07:38 PM
jakematic's Avatar
Check module 53 adaptation channel 006 to see how thick it thinks the pads are.
A function test may also be in order.
You're not getting an 02596 DTC are you ?
ebod0000
A6 (C7 Platform) Discussion
170
06-07-2018 01:39 PM
DannyG123US
09-07-2015 05:53 PM
pattonfrench
09-07-2015 01:11 PM
stormchaser1967
09-02-2015 09:26 AM
C6Silver
Q7 MK 1 Discussion
09-01-2015 08:46 PM
Quick Reply: something odd with function of parking brake
