Too much issues :(
Too much issues :(
Hi im new...ive search for days...no solution for helping.Sorry bad eng my a8 4.0tdi have start up issues on bank rx (lx wheel) randomly start up.I think compressor died??Amber light and when i turn on the screen compressor want charge so very very low impossibile to run.I post the scan here everybody can help me?Tnx to all guys
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 72 76 77
VIN: WAUZZZ4E84N019831 Mileage: 67170km/41737miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: Malfunction 1010
31-Engine other -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 409 F HW: 4E0 907 409 B
Component: 4.0L V8TDI G000AGMª0030
Revision: -------- Serial number: AUX3Z0D0133040
Coding: 0010773
Shop #: WSC 30568 264 67655
VCID: 264841F291301B2ED59
5 Faults Found
18315 - Engine Databus
P1907 - 002 - ECU<->ECU Communications Fault - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Temperature: 36.0°C
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 000 - Open or Short to Plus
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Temperature: 690.2°C
Temperature: -46.4°C
Inj. Quantity: 0.0 mg/str
18282 - Valve for Torque Support Mount
P1874 - 000 - Short to Plus
Freeze Frame:
RPM: 1575 /min
Torque: 156.0 Nm
Speed: 0.0 km/h
Voltage: 12.46 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Temperature: 21.6°C
19591 - Intake Manifold Runner Control
P3135 - 000 - Lower Stop not Reached - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 0.4 %
Temperature: 61.2°C
18061 - Please check DTC Memory of ABS Controller
P1653 - 000 - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 12.54 V
Bin. Bits: 00101100
Torque: 148.2 Nm
Temperature: 28.8°C
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 J HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0010
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 29524ACE802E3456F8B
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0008557
Shop #: WSC 30568 000 00000
VCID: 22405DE2FD18E70EB91
1 Fault Found
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0133040
Coding: 0262144
Shop #: WSC 02311 785 00200
VCID: D8B4BF0A6BC4FDDE175
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 234E58E6E202EE06B27
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 P HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 343AO047525495
Coding: 0000305
Shop #: WSC 12345 123 45725
VCID: 39729A8E708E84D688B
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 301BD047533715
Subsystem 3 - Serial number: 7405.02.040000000000010116ÿ
Subsystem 4 - Serial number: 010116ÿ
7 Faults Found
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
00003 - Control Module
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:32
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:00
Freeze Frame:
Bin. Bits: 01
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:24
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 772 A HW: 4E0 820 043 B
Component: Sitzluefter FS H02 010
Revision: 00000022 Serial number: 00000000036199
Shop #: WSC 00000 000 00000
VCID: 244C5BFAE70CE93ECBD
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 2 - Serial number: 898053000
Subsystem 3 - Serial number: HO05022004065A000000000223ÿ†89
Subsystem 4 - Serial number: 000223ÿ†898053000 000-SHO
Subsystem 5 - Serial number: 000-SHO05022004065A00000000
Subsystem 6 - Serial number: 65A000000000241ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0023001
VCID: 2C5CB3DA8FDC217E03D
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H40 0380
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L V8TDI G000AGSª0030
Coding: 0010773
2 Faults Found
17022 - Throttle Body Actuator Bank 1 (J338)
P0638 - 000 - Implausible Signal
Freeze Frame:
RPM: 651 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Voltage: 14.29 V
Duty Cycle: 95.5 %
Bin. Bits: 00001000
Mass Air / Rev.: 364.3 mg/str
Mass Air / Rev.: 522.9 mg/str
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: E3CE98E622822E06727
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: E5CA86FE2CB650369C3
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 F
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D1003213
Coding: 0000103
VCID: DCBCA31A1FFC11FE33D
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 D
Component: Heizgeraet H06 0290
Revision: 0000000F Serial number: 00000009001484
VCID: D9B2BA0E10CEE4D628B
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 1400303C022CDD
Coding: FCFEFBDE2B3104
2 Faults Found
01342 - Engine Control Module 2 (Slave 1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Reset counter: 24
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:02
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1031999
VCID: 1C3C631ADF7CD1FE73D
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0262144
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 254A46FEEC361036DC3
3 Faults Found
00776 - Level Control System Sensor; Left Front (G78)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 23:02:54
01400 - Suspension Level Control
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 4
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.12.12
Time: 01:13:12
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 9
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:18:51
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4063330
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 305BG047554108
VCID: 3B7E80867AB2B6C69A7
1 Fault Found
02927 - DVD Read Error
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 18
Reset counter: 25
Mileage: 67150 km
Time Indication: 0
Date: 2003.11.13
Time: 08:59:23
Freeze Frame:
Hex Value: 0x3F84
Hex Value: 0x7835
Hex Value: 0x0401
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000402900171
Coding: 0003072
VCID: 1D3A6E1EC466D8F6843
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM007 0110
Coding: 0028448
VCID: DEB8A91209E003EE5D9
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040401270410
Coding: 0000088
VCID: 27564CF6963A0226EEF
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
3 Faults Found
00526 - Brake Light Switch-F
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.20
Time: 03:15:50
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.21
Time: 05:03:26
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 L HW: 4E0 035 223 C
Component: Amp.-Basis H42 0290
Revision: 00000000 Serial number: 00000047524214
Coding: 0000002
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000032575
Coding: 0010101
VCID: 1E386912C960C3EE9D9
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028448
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
Shop #: WSC 01973 264 51111
1 Fault Found
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000002
VCID: E2C09DE23D98270E791
1 Fault Found
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 67144 km
Time Indication: 0
Date: 2003.11.09
Time: 23:11:26
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304B9047560132
Coding: 0000001
VCID: 3162A2AEA8FE4C9630B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000327700
Shop #: WSC 00814 264 02235
VCID: 1F465416CE6ACAE696F
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1401160476
Coding: 303030393135313035414B56413031343031313630343736
Shop #: WSC 00000 128 00289
5 Faults Found
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:57:15
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:25
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:37
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 44
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:21
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 43
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:31
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028448
VCID: DDBAAE1E04E618F6443
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028448
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 08730402901619
Coding: 0001008
VCID: 214252EEF81EFC16A0B
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0770
Revision: 00000001 Serial number: 00000000000000
Coding: 0000004
1 Fault Found
01524 - Antenna for Telephone
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:16:27
Chassis Type: 4E0
Coding: 0010773
5 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Temperature: 36.0°C
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Freeze Frame:
RPM: 1575 /min
Torque: 156.0 Nm
Speed: 0.0 km/h
Voltage: 12.46 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Temperature: 21.6°C
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 0.4 %
Temperature: 61.2°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 12.54 V
Bin. Bits: 00101100
Torque: 148.2 Nm
Temperature: 28.8°C
Coding: 0000001
Coding: 0008557
1 Fault Found
Coding: 0262144
Component: ELV XXXX
Coding: 4063328
Coding: 0000305
7 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:00
Freeze Frame:
Bin. Bits: 01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:24
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Coding: 0023001
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 651 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Voltage: 14.29 V
Duty Cycle: 95.5 %
Bin. Bits: 00001000
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
Coding: 0431707
Coding: 0012141
Coding: 0000103
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Reset counter: 24
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:02
Coding: 0262144
Component: ELV XXXX
Coding: 0015510
3 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 23:02:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.12.12
Time: 01:13:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:18:51
Coding: 4063330
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 25
Mileage: 67150 km
Time Indication: 0
Date: 2003.11.13
Time: 08:59:23
Freeze Frame:
Hex Value: 0x3F84
Hex Value: 0x7835
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0003072
Coding: 0028448
Coding: 0000088
3 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.20
Time: 03:15:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.21
Time: 05:03:26
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Coding: 0000002
Coding: 0010101
Coding: 0028448
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 67144 km
Time Indication: 0
Date: 2003.11.09
Time: 23:11:26
Coding: 0000001
5 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:57:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:25
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:37
Freeze Frame:
Fault Priority: 7
Fault Frequency: 44
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:21
Freeze Frame:
Fault Priority: 7
Fault Frequency: 43
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:31
Coding: 0028448
Coding: 0028448
Coding: 0001008
Coding: 0000004
1 Fault Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:16:27
Way too many faults to try and troubleshoot here. That's whay shops charge what they do to repair vehicles.
Disconnect battery for a few minutes and reconnect. Then start up and clear all faults using the diagnostic software. You should fake the battery monitor unit by pretending to install a new battery . Do this by entering a new serial number for your battery. Just change the last digit. It works wonders, trust all of us here who have done it before.
Then rerun a scan again. You will likely have fewer faults. Then troubleshoot using standard automotive troubleshooting techniques with the assistance of an Audi service manual. If you are not sure how to do this, take classes on car repair at a local school.
Moving parts fail. The WABCO electric air compressor has magnets glued to the motor shell that eventually fall off. On fails first. If this compressor starts running slow, disassemble and re glue all of the magnets using the best epoxy you can get. Also, some have had success replacing the piston ring that wears out. I personally don't think that repair is of much value since it is an oilless compressor. But, what do I know about WABCO products anyway?
Or, Take the car in to a shop and pay them.
Coding: 0010773
5 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Temperature: 36.0°C
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Freeze Frame:
RPM: 1575 /min
Torque: 156.0 Nm
Speed: 0.0 km/h
Voltage: 12.46 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Temperature: 21.6°C
Likely busted engine mount. Check for oil leak/trails on it.
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 0.4 %
Temperature: 61.2°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 12.54 V
Bin. Bits: 00101100
Torque: 148.2 Nm
Temperature: 28.8°C
Coding: 0008557
1 Fault Found
Coding: 0000305
7 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Looks like this module was replaced with a used one and Component Protection was not removed. It must be done by a dealer.
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:00
Freeze Frame:
Bin. Bits: 01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:24
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 651 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Voltage: 14.29 V
Duty Cycle: 95.5 %
Bin. Bits: 00001000
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Reset counter: 24
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:02
Coding: 0015510
3 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 23:02:54
Check this sensor wiring.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.12.12
Time: 01:13:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:18:51
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 25
Mileage: 67150 km
Time Indication: 0
Date: 2003.11.13
Time: 08:59:23
Freeze Frame:
Hex Value: 0x3F84
Hex Value: 0x7835
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0000088
3 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.20
Time: 03:15:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.21
Time: 05:03:26
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 67144 km
Time Indication: 0
Date: 2003.11.09
Time: 23:11:26
5 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:57:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:25
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:37
Freeze Frame:
Fault Priority: 7
Fault Frequency: 44
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:21
Freeze Frame:
Fault Priority: 7
Fault Frequency: 43
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:31
Coding: 0000004
1 Fault Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:16:27
Coding: 0010773
5 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Temperature: 36.0°C
Freeze Frame:
RPM: 0 /min
Torque: 3.9 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.55 V
Freeze Frame:
RPM: 1575 /min
Torque: 156.0 Nm
Speed: 0.0 km/h
Voltage: 12.46 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Temperature: 21.6°C
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
Voltage: 12.08 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 0.4 %
Temperature: 61.2°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 12.54 V
Bin. Bits: 00101100
Torque: 148.2 Nm
Temperature: 28.8°C
Coding: 0008557
1 Fault Found
Coding: 0000305
7 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 238
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:00
Freeze Frame:
Bin. Bits: 01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:17:24
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:19:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 25
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 651 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Voltage: 14.29 V
Duty Cycle: 95.5 %
Bin. Bits: 00001000
Freeze Frame:
RPM: 0 /min
Torque: 19.5 Nm
Speed: 0.0 km/h
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Reset counter: 24
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:52:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:02
Coding: 0015510
3 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 23:02:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.12.12
Time: 01:13:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:18:51
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 25
Mileage: 67150 km
Time Indication: 0
Date: 2003.11.13
Time: 08:59:23
Freeze Frame:
Hex Value: 0x3F84
Hex Value: 0x7835
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0000088
3 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.20
Time: 03:15:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.11.21
Time: 05:03:26
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 67144 km
Time Indication: 0
Date: 2003.11.09
Time: 23:11:26
5 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 07:57:15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:25
Freeze Frame:
Fault Priority: 7
Fault Frequency: 48
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 08:00:37
Freeze Frame:
Fault Priority: 7
Fault Frequency: 44
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:21
Freeze Frame:
Fault Priority: 7
Fault Frequency: 43
Mileage: 67143 km
Time Indication: 0
Date: 2003.11.07
Time: 09:04:31
Coding: 0000004
1 Fault Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 24
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.08
Time: 00:16:27
Save those codes, clear them and post again. We need active codes. Those are history.
first tnx for all assistance!I live in italy...the car start to have issues after 1 month of change battery...rattle and dont start the bank 2,suspension,horn sound issues...and this.Ive coded from dealer here not Audi, i think all this fat problems born for battery so i need to code manually it then try to restart the car.For compressor first i think to go tomorro for buy fuse and relay and try this way.Any other suggestions?
many tnx
best regards
Gabriele
many tnx
best regards
Gabriele
AudiWorld Wiseguy
What is the current age of the car? Most faults appear to have occurred around 10,000km ago and back in 2003? Looks like the fault codes have never been reset?
car is a 2005, ive disconnect battery and ive clean codes today but this S**** laptop fuse on i need to retest again...where is the xenon sensor? g78.And i can try to change firs fuse and relay of compressor under the feet?
The compressor fuse blew for a reason. Most likely the magnet issue I mentioned. A leak in the system could cause it but not as likely. Recode the power/battery manager. Amazing what that will "fix".
Here we go after battery coded front suspension not come up they remain low like 1 cm from road, amber signal and compressor not work.This is the scan after remove errors, so what now?
Saturday,30,August,2014,10:27:49:55062
VCDS Version: Beta 12.10.3
Data version: 20130228
Chassis Type: 4E0
03-ABS Brakes -- Status: OK 0000
11-Engine II -- Status: Cannot be reached 1100
31-Engine other -- Status: Cannot be reached 1100
37-Navigation -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Temperature: 23.4°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Readiness: 0 0 1 1 1
Cannot be reached
Coding: 0008557
Coding: 0262144
Component: ELV XXXX
Coding: 4063328
Coding: 0000305
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:43
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Coding: 1054721
VCID: DAB0A50215C8EFCE211
Subsystem 2 - Part No: 4E0 910 772 A
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO05022004065A000000000223ÿ†89
Subsystem 5 - Serial number: 000223ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO05022004065A00000000
Subsystem 7 - Serial number: 65A000000000241ÿ
Coding: 0023001
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Component: 4.0L V8TDI 0030
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 0431707
Coding: 0012141
Coding: 0000103
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:48
Coding: 0262144
Component: ELV XXXX
Coding: 0015510
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:28
Coding: 4063330
Coding: 0003072
Coding: 0028448
Coding: 0000088
1 Fault Found
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Coding: 0000002
Coding: 0010101
Coding: 0028448
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
Coding: 0000001
Subsystem 1 - Part No: 009 151 05D L
Component: von VA0 331029T1JQ
Coding: 3030393135313035444C2056413033333130323954314A51
Shop #: WSC 12345 128 00289
Coding: 0028448
Coding: 0028448
Coding: 0001008
Coding: 0000004
End ---------------------------------------------------------------------
Chassis Type: 4E0
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Temperature: 23.4°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Cannot be reached
Coding: 0008557
Coding: 0262144
Component: ELV XXXX
Coding: 4063328
Coding: 0000305
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:43
Coding: 1054721
Coding: 0023001
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
No Faults Found
Coding: 0431707
Coding: 0012141
Coding: 0000103
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:48
Coding: 0262144
Component: ELV XXXX
Coding: 0015510
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:28
Coding: 4063330
Coding: 0003072
Coding: 0028448
Coding: 0000088
1 Fault Found
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Coding: 0000002
Coding: 0010101
Coding: 0028448
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
Coding: 0000001
Coding: 0028448
Coding: 0028448
Coding: 0001008
Coding: 0000004
Chassis Type: 4E0
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Temperature: 23.4°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Cannot be reached
Coding: 0008557
Coding: 0262144
Component: ELV XXXX
Coding: 4063328
Coding: 0000305
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:43
Coding: 1054721
Coding: 0023001
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
No Faults Found
Coding: 0431707
Coding: 0012141
Coding: 0000103
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:48
Coding: 0262144
Component: ELV XXXX
Coding: 0015510
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:28
Coding: 4063330
Coding: 0003072
Coding: 0028448
Coding: 0000088
1 Fault Found
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Coding: 0000002
Coding: 0010101
Coding: 0028448
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
Coding: 0000001
Coding: 0028448
Coding: 0028448
Coding: 0001008
Coding: 0000004
Chassis Type: 4E0
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Temperature: 23.4°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Cannot be reached
Coding: 0008557
Coding: 0262144
Component: ELV XXXX
Coding: 4063328
Coding: 0000305
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:43
Coding: 1054721
Coding: 0023001
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
No Faults Found
Coding: 0431707
Coding: 0012141
Coding: 0000103
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:48
Coding: 0262144
Component: ELV XXXX
Coding: 0015510
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:28
Coding: 4063330
Coding: 0003072
Coding: 0028448
Coding: 0000088
1 Fault Found
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Coding: 0000002
Coding: 0010101
Coding: 0028448
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
Coding: 0000001
Coding: 0028448
Coding: 0028448
Coding: 0001008
Coding: 0000004
Chassis Type: 4E0
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Temperature: 23.4°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Cannot be reached
Coding: 0008557
Coding: 0262144
Component: ELV XXXX
Coding: 4063328
Coding: 0000305
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:43
Coding: 1054721
Coding: 0023001
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
No Faults Found
Coding: 0431707
Coding: 0012141
Coding: 0000103
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:48
Coding: 0262144
Component: ELV XXXX
Coding: 0015510
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:28
Coding: 4063330
Coding: 0003072
Coding: 0028448
Coding: 0000088
1 Fault Found
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Coding: 0000002
Coding: 0010101
Coding: 0028448
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
Coding: 0000001
Coding: 0028448
Coding: 0028448
Coding: 0001008
Coding: 0000004
Chassis Type: 4E0
Coding: 0010773
2 Faults Found
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Temperature: 23.4°C
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.40 V
Cannot be reached
Coding: 0008557
Coding: 0262144
Component: ELV XXXX
Coding: 4063328
Coding: 0000305
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 56950 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:43
Coding: 1054721
Coding: 0023001
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
No Faults Found
Coding: 0431707
Coding: 0012141
Coding: 0000103
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:48
Coding: 0262144
Component: ELV XXXX
Coding: 0015510
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 67172 km
Time Indication: 0
Date: 2003.10.14
Time: 20:33:28
Coding: 4063330
Coding: 0003072
Coding: 0028448
Coding: 0000088
1 Fault Found
Freeze Frame:
Fault Priority: 3
Reset counter: 240
Mileage: 58506 km
Time Indication: 0
Date: 2003.10.10
Time: 09:36:16
Coding: 0000002
Coding: 0010101
Coding: 0028448
Revision: AV1C1010
Coding: 0000431
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 61
Coding: 0000002
Coding: 0000001
Coding: 0028448
Coding: 0028448
Coding: 0001008
Coding: 0000004
