Wire Harness and plug under Battery Compartment
#11
Banned
Did you look at the PDF posted by ScottCNelson in post # 3, it shows the location of EPBCM under battery.
That does not look at all like the air suspension control module connector, it looks to be as already stated the "EPB" electric parking brake control module connector.
4E0907801 | eBay
#12
I would have started with this. There is a member here (wug) who will run your vin number, that may give you a starting point of everything your car is supposed to have.
https://www.audiworld.com/forums/a8-...843984/page27/
#13
Given the optical lines not damage to u need to get atleast amp and radio tuner to get going, close loop the rest get cd changer also if it missing from the glove box, only amp and cd changer need component protection removed, if radio has sds that to, if you don't have factory bluetooth which I didn't see in the scan it's unlikely you had sds, so a non sds tuner will do.
#14
Hello Yllier,
4E0907801 | eBay
4E0907801 | eBay
Lucas Larson
02-27-2020 09:37 AM
AudiQmann
02-25-2006 04:04 AM
Thom
03-18-2004 09:35 AM
