A8 D4 Bang & Olufsen scan
Hello all,
I have done a retrofit of B&O on my car and need some help regarding the coding, I really need a scan of a B&O car to compare the 5F and 47 data.
If anyone can help then it would be very much appreciated.
Many thanks
Alan
Many thanks
Alan
Here are the results from a 2011 A8 3.0 TDi with B&O...
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
Address 47: Sound System (J525) Labels: None
Part No SW: 4H0 035 465 A HW:
Component: BO G3 D4 H06 0150
Revision: 04S00000 Serial number: 0012023
Shop #: WSC 02313 785 00200
VCID: 24475449279BEC3EDF5-8071
Subsystem 1 - Part No SW: 4H0 035 466 HW: 4H0 035 466
Component: BO D4 SLAVE H51 0180
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 670 F HW: 4H0 035 670 C
Component: H-BNT-EU H41 0239
Revision: -------- Serial number: 060BR0B7505195
Coding: 020101000001F9EF65108B1E000000030000010000000000
Shop #: WSC 02311 785 00200
VCID: 275D434556AD0726FA7-8072
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4H0 919 604 C HW: 4H0 919 604 C
Component: DU8 D4 SV NB H46 0021
Subsystem 3 - Part No SW: 4H2 919 600 D HW: 4H2 919 600
Component: E380 BDT D4 H09 0063
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Adam
Adam,
That is a massive help, your sound system has the same version codes as mine and your 5F coding has only 2 digits different, neither relate to the sound system. I think my problem might be in my sound system adaptation settings, Rosstech have suggested I do a control map scan of the 47 unit which I have now done for the first time, would it be possible for you to do that for me?
on the opening page of VCDS select "applications" then type 47 in the address box, select the "adaptation" check box then "run". this should save a file in your logs folder.
If you could do the same but select the "Measuring blocks" check box then that should save the measuring blocks.
none of this will change anything in your system.
Many thanks
Alan
Many thanks
Alan
Alan
See results below for adaption channels and measuring blocks.
Regards
Adam
;SW:4H0-035-465-A HW: --- Sound System
;Component:BO G3 D4 H06 0150, Coding:
;Friday,24,October,2014,10:36:53:16403
;VCDS Version: Release 12.12.3 (x64) Data version: 20140822
;VCID: 24475449279BEC3EDF5-8071
;01 N/A
;02 N/A
;03 N/A
;04 N/A
;05 N/A
;06 N/A
;07 N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
A96,0,
;0
A96,1,
;N/A
A96,2,
;N/A
A96,3,
;N/A
A96,4,
;N/A
;97 N/A
;98 N/A
A99,0,
;2
A99,1,
;N/A
A99,2,
;N/A
A99,3,
;N/A
A99,4,
;N/A
A100,0,
;0
A100,1,
;N/A
A100,2,
;N/A
A100,3,
;N/A
A100,4,
;N/A
A101,0,
;0
A101,1,
;N/A
A101,2,
;N/A
A101,3,
;N/A
A101,4,
;N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
A111,0,
;0
A111,1,
;N/A
A111,2,
;N/A
A111,3,
;N/A
A111,4,
;N/A
A112,0,
;90
A112,1,
;N/A
A112,2,
;N/A
A112,3,
;N/A
A112,4,
;N/A
A113,0,
;3
A113,1,
;N/A
A113,2,
;N/A
A113,3,
;N/A
A113,4,
;N/A
A114,0,
;100
A114,1,
;N/A
A114,2,
;N/A
A114,3,
;N/A
A114,4,
;N/A
A115,0,
;10000
A115,1,
;N/A
A115,2,
;N/A
A115,3,
;N/A
A115,4,
;N/A
A116,0,
;20
A116,1,
;N/A
A116,2,
;N/A
A116,3,
;N/A
A116,4,
;N/A
A117,0,
;10
A117,1,
;N/A
A117,2,
;N/A
A117,3,
;N/A
A117,4,
;N/A
A118,0,
;0
A118,1,
;N/A
A118,2,
;N/A
A118,3,
;N/A
A118,4,
;N/A
A119,0,
;0
A119,1,
;N/A
A119,2,
;N/A
A119,3,
;N/A
A119,4,
;N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
1,0,,
1,1,,,
;11.80 V,Voltage,
1,2,,,
;00000111,Bin. Bits,
1,3,,,
;0.0,(no units),
1,4,,,
;N/A,,
2,0,,
2,1,,,
;0x0547,Hex Value,
2,2,,,
;0x03FF,Hex Value,
2,3,,,
;0x0047,Hex Value,
2,4,,,
;N/A,,
3,0,,
3,1,,,
;0.00,(no units),
3,2,,,
;18.0°C,Temperature,
3,3,,,
;74.0°C,Temperature,
3,4,,,
;N/A,,
4,0,,
4,1,,,
;0x0000,Hex Value,
4,2,,,
;N/A,,
4,3,,,
;N/A,,
4,4,,,
;N/A,,
5,0,,
5,1,,,
;0x00FF,Hex Value,
5,2,,,
; 1,Bin. Bits,
5,3,,,
;N/A,,
5,4,,,
;N/A,,
6,0,,
6,1,,,
;0x0001,Hex Value,
6,2,,,
;0xCAB8,Hex Value,
6,3,,,
;N/A,,
6,4,,,
;N/A,,
7,0,,
7,1,,,
;0x0100,Hex Value,
7,2,,,
;0x3AB0,Hex Value,
7,3,,,
;0xAA3A,Hex Value,
7,4,,,
;N/A,,
8,0,,
8,1,,,
; 10,Bin. Bits,
8,2,,,
;00000100,Bin. Bits,
8,3,,,
;N/A,,
8,4,,,
;N/A,,
9,0,,
9,1,,,
;0.0 km/h,Speed,
9,2,,,
;0 /min,RPM,
9,3,,,
;0.0 A,Current,
9,4,,,
; 0,Bin. Bits,
10,0,,
10,1,,,
;0.12 V,Voltage,
10,2,,,
;N/A,,
10,3,,,
;N/A,,
10,4,,,
;N/A,,
11,0,,
11,1,,,
;17.0°C,Temperature,
11,2,,,
;19.0°C,Temperature,
11,3,,,
;22.0°C,Temperature,
11,4,,,
;21.0°C,Temperature,
12,0,,
12,1,,,
;23.0°C,Temperature,
12,2,,,
12,3,,,
12,4,,,
;0 dB,Attenuation,
13,0,,
13,1,,,
;0 /min,RPM,
13,2,,,
;N/A,,
13,3,,,
;N/A,,
13,4,,,
;N/A,,
14,0,,
14,1,,,
;11.80 V,Voltage,
14,2,,,
;7.70 V,Voltage,
14,3,,,
;5.00 V,Voltage,
14,4,,,
;2.50 V,Voltage,
15,0,,
15,1,,,
;11.60 V,Voltage,
15,2,,,
;22.00 V,Voltage,
15,3,,,
;1.80 V,Voltage,
15,4,,,
;N/A,,
16,0,,
16,1,,,
;12.00 V,Voltage,
16,2,,,
;39.00 V,Voltage,
16,3,,,
;38.50 V,Voltage,
16,4,,,
;5.03 V,Voltage,
17,0,,
17,1,,,
;12.38 V,Voltage,
17,2,,,
;5.13 V,Voltage,
17,3,,,
;5.67 V,Voltage,
17,4,,,
;10.09 V,Voltage,
18,0,,
18,1,,,
;00010101,Bin. Bits,
18,2,,,
;HI, ,
18,3,,,
;HI, ,
18,4,,,
;N/A,,
19,0,,
19,1,,,
;16.0°C,Temperature,
19,2,,,
19,3,,,
19,4,,,
20,0,,
20,1,,,
20,2,,,
20,3,,,
20,4,,,
;0.0 %,Load,
32,0,,
32,1,,,
;00100000,Bin. Bits,
32,2,,,
;00000010,Bin. Bits,
32,3,,,
;0x215B,Hex Value,
32,4,,,
;2010:04:16,Date,
48,0,,
48,1,,,
;00000000 00000000,Bin. Bits,
48,2,,,
;00:00,Clock,
48,3,,,
;0.0,(no units),
48,4,,,
;N/A,,
Regards
Adam
;01 N/A
;02 N/A
;03 N/A
;04 N/A
;05 N/A
;06 N/A
;07 N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
A96,0,
;0
A96,1,
;N/A
A96,2,
;N/A
A96,3,
;N/A
A96,4,
;N/A
;97 N/A
;98 N/A
A99,0,
;2
A99,1,
;N/A
A99,2,
;N/A
A99,3,
;N/A
A99,4,
;N/A
A100,0,
;0
A100,1,
;N/A
A100,2,
;N/A
A100,3,
;N/A
A100,4,
;N/A
A101,0,
;0
A101,1,
;N/A
A101,2,
;N/A
A101,3,
;N/A
A101,4,
;N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
A111,0,
;0
A111,1,
;N/A
A111,2,
;N/A
A111,3,
;N/A
A111,4,
;N/A
A112,0,
;90
A112,1,
;N/A
A112,2,
;N/A
A112,3,
;N/A
A112,4,
;N/A
A113,0,
;3
A113,1,
;N/A
A113,2,
;N/A
A113,3,
;N/A
A113,4,
;N/A
A114,0,
;100
A114,1,
;N/A
A114,2,
;N/A
A114,3,
;N/A
A114,4,
;N/A
A115,0,
;10000
A115,1,
;N/A
A115,2,
;N/A
A115,3,
;N/A
A115,4,
;N/A
A116,0,
;20
A116,1,
;N/A
A116,2,
;N/A
A116,3,
;N/A
A116,4,
;N/A
A117,0,
;10
A117,1,
;N/A
A117,2,
;N/A
A117,3,
;N/A
A117,4,
;N/A
A118,0,
;0
A118,1,
;N/A
A118,2,
;N/A
A118,3,
;N/A
A118,4,
;N/A
A119,0,
;0
A119,1,
;N/A
A119,2,
;N/A
A119,3,
;N/A
A119,4,
;N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
1,0,,
1,1,,,
;11.80 V,Voltage,
1,2,,,
1,3,,,
;0.0,(no units),
1,4,,,
;N/A,,
2,0,,
2,1,,,
;0x0547,Hex Value,
2,2,,,
;0x03FF,Hex Value,
2,3,,,
;0x0047,Hex Value,
2,4,,,
;N/A,,
3,0,,
3,1,,,
;0.00,(no units),
3,2,,,
3,3,,,
3,4,,,
;N/A,,
4,0,,
4,1,,,
;0x0000,Hex Value,
4,2,,,
;N/A,,
4,3,,,
;N/A,,
4,4,,,
;N/A,,
5,0,,
5,1,,,
;0x00FF,Hex Value,
5,2,,,
; 1,Bin. Bits,
5,3,,,
;N/A,,
5,4,,,
;N/A,,
6,0,,
6,1,,,
;0x0001,Hex Value,
6,2,,,
;0xCAB8,Hex Value,
6,3,,,
;N/A,,
6,4,,,
;N/A,,
7,0,,
7,1,,,
;0x0100,Hex Value,
7,2,,,
;0x3AB0,Hex Value,
7,3,,,
;0xAA3A,Hex Value,
7,4,,,
;N/A,,
8,0,,
8,1,,,
; 10,Bin. Bits,
8,2,,,
8,3,,,
;N/A,,
8,4,,,
;N/A,,
9,0,,
9,1,,,
;0.0 km/h,Speed,
9,2,,,
;0 /min,RPM,
9,3,,,
;0.0 A,Current,
9,4,,,
; 0,Bin. Bits,
10,0,,
10,1,,,
;0.12 V,Voltage,
10,2,,,
;N/A,,
10,3,,,
;N/A,,
10,4,,,
;N/A,,
11,0,,
11,1,,,
11,2,,,
11,3,,,
11,4,,,
12,0,,
12,1,,,
12,2,,,
12,3,,,
12,4,,,
;0 dB,Attenuation,
13,0,,
13,1,,,
;0 /min,RPM,
13,2,,,
;N/A,,
13,3,,,
;N/A,,
13,4,,,
;N/A,,
14,0,,
14,1,,,
;11.80 V,Voltage,
14,2,,,
;7.70 V,Voltage,
14,3,,,
;5.00 V,Voltage,
14,4,,,
;2.50 V,Voltage,
15,0,,
15,1,,,
;11.60 V,Voltage,
15,2,,,
;22.00 V,Voltage,
15,3,,,
;1.80 V,Voltage,
15,4,,,
;N/A,,
16,0,,
16,1,,,
;12.00 V,Voltage,
16,2,,,
;39.00 V,Voltage,
16,3,,,
;38.50 V,Voltage,
16,4,,,
;5.03 V,Voltage,
17,0,,
17,1,,,
;12.38 V,Voltage,
17,2,,,
;5.13 V,Voltage,
17,3,,,
;5.67 V,Voltage,
17,4,,,
;10.09 V,Voltage,
18,0,,
18,1,,,
18,2,,,
;HI, ,
18,3,,,
;HI, ,
18,4,,,
;N/A,,
19,0,,
19,1,,,
19,2,,,
19,3,,,
19,4,,,
20,0,,
20,1,,,
20,2,,,
20,3,,,
20,4,,,
;0.0 %,Load,
32,0,,
32,1,,,
32,2,,,
32,3,,,
;0x215B,Hex Value,
32,4,,,
;2010:04:16,Date,
48,0,,
48,1,,,
48,2,,,
;00:00,Clock,
48,3,,,
;0.0,(no units),
48,4,,,
;N/A,,
Adam you are a gent. thanks for that. unfortunately it has not improved things as the adaptations were identical however the measuring blocks are quite different and whereas your amp was coded in 2010 ours says 2000 i.e. in my mind never coded. The seller did say after the sale that the amp was new but not boxed. the real problem is that Audi cannot code the amp as the settings are sent via computer link from Germany and as my car was never equipped from the factory with B&O then it will not code it.
Thanks very much for your help.
Alan
Alan
bballfreak
9
04-14-2019 06:59 PM
ECS Tuning-Audi
RS4 (B7 Platform) Discussion
08-14-2017 08:39 AM
ECS Tuning-Audi
09-28-2015 12:18 PM
ECS Tuning-Audi
09-28-2015 11:46 AM
