Sponsored by:
Sponsored by:
Center speaker rattle ? Bose
Old 12-07-2016, 04:23 PM
  #11
Jsmithdmi's Avatar
Originally Posted by AMDG75
If it is similar to the A6, the grill is easy to pry off (start at corner closest to passenger seat), and you will need a 5.5 mm socket. Not being able to control the overwhelming output of this speaker, I disconnected it.
I have removed my center console speaker but as many of you have mentioned that speaker must blow easily. It looks like a new one is 120 bucks and I have to imagine a better speaker is available vs this Bose paper stuff. Anyone know what will fit or am I stuck getting a new replacement speaker.
Old 12-07-2016, 07:38 PM
  #12
tenspeed's Avatar
Check the A6/A7 C7 sections. There is more than one thread about the Bose center speaker replacement.
Old 02-28-2019, 11:25 PM
  #13
mpelanti's Avatar
My Bose center speaker rattled a lot with phone calls and navigation cues (also with some music!) so I decided to replace it with the original 4H0035402 speaker, price was 118 euros from the dealer.
Rattles are now gone! So well worth the effort! Change took 30 mins, most of the time spent for getting the grill out, otherwise the replacement is very easy.
Old 03-07-2019, 06:57 AM
  #14
mhoran89's Avatar
Received 1,171 Likes on 915 Posts
I had the B&O speaker system in my '14 A8L and I had the same muffled rattling calls coming through (or sometimes on FM radio).
Anyone experience this with B&O instead of BOSE or am I the only one.
Old 03-07-2019, 07:20 AM
  #15
Jibsymalone's Avatar
I too have distortion out of the center speaker on my B&O. Sometimes it seems worse than others, with certain frequencies being more affected than others. I too have briefly looked into a replacement center speaker for this reason...
Old 03-07-2019, 05:18 PM
  #16
mhoran89's Avatar
correct it is definitely provoked by certain frequencies
Old 09-02-2023, 05:48 AM
  #17
jlouis141's Avatar
Originally Posted by dildildil
guys i have a rattle coming from front center speaker on my new to me 2011 audi a8l with factory bose audio... my friend who has a same year same option car has the same issue, is it the speaker thats blown or is it the grill rattle ? some songs its perfectly fine some its horrible and its bad on phone calls and navigation commands if the volume is up ?
how does one remove the speaker grill on that dash to figure if its the grill or speaker itself?
thank you
easier than you think just need a pry tool a good socket set and the hex bit to unscrew the speaker. I'm trying to repair my speaker first with epoxy.
Old 09-02-2023, 12:10 PM
  #18
snapdragon's Avatar
I think the Sat Nav commands, BT phone and Speech Dialogue use the garbage speaker in the cluster. Listen where it comes from.
Old 10-29-2023, 10:47 PM
  #19
jigaro's Avatar
I'm having the same issue, I will try to take a look at the speaker, if it is damaged i guess i will have to replace it. It has the rattle only at certain frequencies.
Old 11-01-2023, 01:55 PM
  #20
fjord's Avatar
While tracing a rattle on my 2014 I ran upon this video which so far has fixed 2 speakers for me:
Quick Reply: Center speaker rattle ? Bose
