Possible engine swap for 2011 A8 ? (with 4.0 T)
Is it possible to put 4.0 T in to replace 4.2 ? Trying to find out NOW not for "future project". Car is in shop already!! Thank you for any input !!
Why would you want to do it? The 4.2 is really good as is and if you want the 4.0T why not just get a car with it in the first place? I cant see how you would get your hands on a 4.0T engine and put it in another D4 and making it work financially, not to mention all the control units and re-coding issues you would likely get. If you did it and wanted to sell no one would buy it until its really, really old and cost nothing.
Swapping the engine might be the easiest part of the whole deal. You'd have to install the special variable cylinder engine mount vibration dampeners which may entail a different sub-chassis structure; there is also the Variable cylinder noise canceling setup that runs through the sound system; a host of software mapping upgrades, not to mention possible changes to the 8-speed transmission to deal with the increase in torque; and I'm not sure about possible changes to the cooling system.
Perhaps it's doable, but I have a sneaking feeling that it's just not that simple, and goes well beyond the engine alone.
The good old days of dragging an old 34 Ford into the garage and buying a few adapters and sticking a small block Chevy in it are long gone. My guess is that engine swamps just one year to the next with the "same" engine would be pretty involved today.
+1. Never gonna happen. 10 years ago it was already at the point of being next to impossible and get it street titled with all the right smog and all. Today i would say next to impossible, maybe even to get it to a reasonable driving condition let alone DMV type compliance issues. Think about even the basics of swapping over the ECU that will be different, the related harness, the security programming on the ECU, how it talks with the MMI dynamic stuff, what the ECU tells the TCU, and on and on.
Yes same conclusion not worth the time/expense!! Extended warranty will replace my 4.2 with a new factory fresh long block and that is how it will go. Thank all of you that replied - much appreciated! Cheers....
Baloo588
11
06-24-2012 08:45 AM
Real-Q
Quattro: Turbo / Ur / Sport
03-28-2006 04:00 PM
