no start on my 12v rebuild!
Old 03-04-2009, 04:39 AM
AUDI GT1's Avatar
Default no start on my 12v rebuild!
i finally got my engine installed on my a6 and i turned it over with no spark plug wires and no oil just to make sure it cranked over fine and to check for a fuel leak and she spun over fine. i put oil in her and plug wires pressurized the lines again and nothing no dimming nothing and it sounds like a vaccum pump is running when the key is on the starter is getting juice and it points to a bad starter but are there any other possible things that would stop it from cranking over?
Old 03-04-2009, 06:30 AM
rmccomiskie's Avatar
Bad ignition switch.
Old 03-05-2009, 04:44 AM
AUDI GT1's Avatar
Default Re: Bad ignition switch.
But i get power to the cable for the starter.Ill find out this weekend.
me thinks its a bad wire or the starter sleeping on it for a few says most likely culprit is the solenoid.
Old 03-05-2009, 05:50 AM
Default Put a jumper across the starter terminals...
If the starter engages then the ignition switch is the problem.
Old 03-06-2009, 04:31 AM
AUDI GT1's Avatar
Default have to wait to work on her.
cant wait until this weekend. i only have the shop on Saturdays during school which makes the process take much longer.
audithepeanut
9
09-07-2008 04:34 PM
5000Q86
07-14-2008 07:10 PM
forcefedfreak
12
04-27-2008 12:19 AM
lesk123
08-05-2007 06:59 AM
CastleCQ
05-30-2004 03:45 PM
Quick Reply: no start on my 12v rebuild!
