What oil rear part auto
Old 04-19-2015, 10:22 AM
Skylinekrille's Avatar
Default What oil rear part auto
What oil and how much should it be in the rear part of the Audi A6 C4 quattro automatic tranny? cant seem to find any info of it, only info how to change the transmission fluid and thats not the same
Old 04-26-2015, 03:34 PM
Prospeeder's Avatar
the quattro torsen uses synthetic gear oil. Like 80-90 or 75-90 or what evers close, its really not picky. It doesnt even hold a quart. Just keep the car level and pump it in till it runs out.
Old 05-24-2015, 12:13 PM
Okey thanks, i noticed to late that it was out of oil in this part so it failed hard making the car almost not move forward. Luckely i had another gearbox so i just changed the torsen at the rear, and it worked, not i didnt change the big metal can thingy that seems to be the connection from the acutal gearbox part with the torsen part, should i have done that to?
The car runs fine, only thing i notice is that when i accelerate the car vibrates a bit at the low revs for some reason, i have double checked the bolts and all, im thinking if it has something to do with the big metal can inside the gearbox? if it got damaged some how when the torsen ran out of oil?
Old 05-25-2015, 12:54 PM
Prospeeder's Avatar
The vibrating is going to be related to the drive line, like the center bearing. Did you make sure to bolt the bearing back in the exact same spot. The 2 13mm that hold the center bearing up are adjustable, odd loads on the bearing can cause vibration.
Old 06-01-2015, 01:36 AM
Okey, i checked the bearing, and also tried to adjust it a bit, didnt notice any difference, but i will check it again
ernestolopez
07-03-2010 05:14 PM
sgupta126
01-27-2006 07:15 AM
4Driver4
Audi Original "S" Cars
04-19-2005 06:00 PM
eltako
Audi 100 / A6 (C4 Platform)
04-08-2005 08:26 AM
Xel
02-07-2003 11:41 PM
Quick Reply: What oil rear part auto
