CONVERTING REAR DISCS TO BACK TO DRUM
Old 10-02-2014, 01:24 PM
mar5den's Avatar
Default CONVERTING REAR DISCS TO BACK TO DRUM
HI ALL IM IN A BIT OF A PICKLE IM TRYING TO GET 2 REAR HUBS FOR MY AUDI BUT IM HAVING A LITTLE TROULBE IVE ONLY FOUND ONE SITE THAT SELLS THEM AND THE PRICE IS TO HIGH WHAT WOULD I NEED AND IS IT EASY TO SWAP OVER BACK TO DRUM?????
Old 10-02-2014, 04:39 PM
jchrisyoungren's Avatar
Maybe you could find the part number stamped on your hubs, and search from there?
Old 10-02-2014, 04:44 PM
Default Probably from a Jetta or Scirocco
Ah, I just saw your other post regarding the part numbers. The disk brake swap most likely used parts from a Jetta, or the entire rear axle could have been swapped for one from a Scirocco. I start there, rather than revert to drums.
Old 10-02-2014, 06:12 PM
Rogviler's Avatar
Do you have junkyards there? That would be your best bet. The hub is easy to get off, as you probably figured out. While you're at it, you could get the front hubs to swap as well, though you'll need a press and a new bearing for each side (and of course get the rotors or drill your old ones). If I can ever get someone to sell me a 4x108 front hub I'd even send you my 4x100 pair.
Did you measure the bolt spacing of the hubs? Just so we know we're on the right track...
-Rog
Old 10-12-2014, 01:02 PM
Old_School_Audi's Avatar
-STOP-
The 4000 and the VW A1 do not share the "entire" rear axle. Please be carefull when making such statements. You may end up costing someone a lot of time and $ if they believe that. Please make sure you have accurate information when posting...
Old 10-12-2014, 02:14 PM
Rogviler's Avatar
Originally Posted by Old_School_Audi
-STOP-
What's the difference then?
-Rog
N'Syncro
33
02-16-2020 03:12 PM
winter
09-07-2016 04:38 PM
Buckwheat2088
09-12-2015 07:01 AM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
Quick Reply: CONVERTING REAR DISCS TO BACK TO DRUM
