Stuck injector tip (cap, aircap, hat)?
Old 09-13-2014, 04:32 PM
Rogviler's Avatar
Default Stuck injector tip (cap, aircap, hat)?
Monkeying with my project car again... I pulled all the injectors to find them glued shut with varnish, so there's a mystery solved. However, one of the tips got stuck in the head, so I thought I'd share an idea I had that worked out really well, since I found no good ideas through searching.
I did NOT want to pull the intake manifold and especially not the head, so I threaded a wood screw into the hole in the center of the cap and that gave me something to grab onto. That way it came out easily. I also had removed the brass injector holder (in the hopes that maybe the cap was stuck to it), but that's probably not necessary. Of course you'll probably need a new cap, but who doesn't have some extras...
File it!
-Rog
Old 11-10-2023, 08:04 AM
Emanjo's Avatar
Default Trying to locate those things new,
Im planning on resealing my injectors soon and can't find that 'hat' part for the KX's anywhere. It actually wasn't til I already ordered the wrong sleeves that I realized the interference/ non engines had different injector sleeves. There a chance these r the kind of thing a local parts store would have on hand?
Old 11-11-2023, 06:43 AM
Gregar's Avatar
Hi Rog,
what engine is that from? My jt would not accept the hats so I removed them. Not sure, but I might have them if you need them.
fmladineo
Q7 MK 1 Discussion
9
05-03-2022 10:55 PM
bballfreak
9
04-14-2019 06:59 PM
Kerry G
05-18-2018 06:12 AM
Buckwheat2088
Q5/SQ5 MKI (8R) Discussion
09-28-2015 06:26 PM
Quick Reply: Stuck injector tip (cap, aircap, hat)?
