1994 Audi Cabriolet fuse block
Old 07-06-2016, 06:44 AM
GJSZ51's Avatar
Default 1994 Audi Cabriolet fuse block
New to this forum and would like to thank all for allowing me to join up.
I have a Audi 1994 cabriolet that the under cowl fuse block cover has been lost. Started with an intermittent no start. Finally traced to the fuse block. The fuel pump relay was so coroded one of the relay legs broke off on removal. We also have intermittent window operations which I attribute to the same fuse/relay block.
Long story short... I want to replace the fuse block. I have been able to locate a lid but no block. I am told
it is discontinued. I would like to find the fuse box with lid and all the relays.
I was hoping folks here might be able to steer me to the appropriate source.
Thanks, in advance, for all help!
GJS
Old 07-06-2016, 07:27 AM
Rusty Spokes's Avatar
Your best bet may be a local bone yard..Audi 90s had the same fuse box (I'm sure) Where are you located? A WTB posted here and over at QW may be a solution. Green Machine over on quatto-world seems to have some Cabriolet spares collected. his email is bradlarz@gmail dot com
Old 07-06-2016, 07:42 AM
GJSZ51's Avatar
Thanks, Rusty. I thought there might be other applications.
Old 07-06-2016, 08:13 AM
The part number for a 1994 Cabriolet fuse block is 443941822A and there are a few out there. That block is an insert into the box holder..you need the fuse block. Google the part number..I found one in europe for 14 euros..https://shop.euroimpex.lt/en/dalis/27422/fuse-box-
Old 07-06-2016, 08:21 AM
See if this fellow will ship to the USA. On the german ebay site some do and some don't. You have to ask. This fusebox is complete with relays..in Germany.
Audi Coupe 89 8B Sicherungskasten Zentralelektrik Raleis 893941803A 443941822A | eBay
Old 07-06-2016, 08:26 AM
GJSZ51's Avatar
Thanks Rusty
I have determined I need part numbers
Cover. 8A0941801
Plate. 443941822A
Housing. 8A0941803
Old 07-06-2016, 03:32 PM
grillage's Avatar
You may be able to soak it in CLR overnight and reinstall.
I have a similar issue with my Coupe.
Can't hurt to try
Old 07-18-2016, 11:20 PM
jnsluft's Avatar
GJS
I can source a fuse box from a local salvage yard. They have a '94 90S. Let me know if you're interested.
Shawn
Old 09-10-2019, 11:16 AM
Heather Drapal's Avatar
Default Relay location 2 & 11?
Are there supposed to be relays in 2 and 11 ? I have a 1997 Audi Cabriolet and I don’t have relays in 2&11 either but as per a manual it says 2&11 are radiator relays.
GJS
Old 09-11-2019, 10:35 AM
Heather..those radiator relays are behind the driver's side kick panel under the dash..hidden.
Relay #18 is a high speed fan. As I recall #17 relay is a second speed fan, not vacant. See the Bentley manual attachment. Audi did a poor job of documenting their work.
Relay location 2 & 11? No. Not in USA
Quick Reply: 1994 Audi Cabriolet fuse block
