93 90 cs won't start
Old 07-02-2013, 02:42 PM
randy83's Avatar
Default 93 90 cs won't start
My gf has a 93 audi 90cs.. Check engine light came on she shut it off and checked the oil now it won't start.. Fuel pump works and has spark. Won't fire up.. Any ideas or fixes.. I have an idea there is something wrong with wiring or with factory security system
Old 07-02-2013, 05:51 PM
jbasilio95b4's Avatar
Ok it can be alot of things, scan for codes,following the instructions and find out what sensor is popping up a code.
http://12v.org/maintenance/dtc.php
Old 07-03-2013, 10:18 AM
randy83's Avatar
It was running great when she shut it off ..but where do ibid a comp to check codes on this from what iv been told its not odb 1 and any us code reader won't work
Old 07-03-2013, 02:53 PM
egp320i's Avatar
A 93 is OBD1 but you need a 2x2 VAG connector in order to hook it to a modern scanner to pull up codes.
That or you have to do it the hard way with blink codes which can be tricky.
Inside your fuse box will be a black and white connector that is shape keyed, black is for power, white is the data link.
<a href="http://tinypic.com?ref=18dw5z" target="_blank"><img src="http://i41.tinypic.com/18dw5z.gif" border="0" alt="Image and video hosting by TinyPic"></a>
To do the blink codes easily you need this factory connector, good luck finding one though if you did not buy it a long time ago.
<a href="http://tinypic.com?ref=30t5o2s" target="_blank"><img src="http://i44.tinypic.com/30t5o2s.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
OBD 1 to OBD2 connector looks like this.
<a href="http://tinypic.com?ref=2uqeoav" target="_blank"><img src="http://i42.tinypic.com/2uqeoav.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old 07-05-2013, 03:40 PM
grillage's Avatar
All you need is a paper clip to pull codes.
Old 07-05-2013, 10:22 PM
egp320i's Avatar
True in a pinch you can use a paper clip. I happened to find this factory connector in the glove box when I bought my car.
Course since I have a scanner and 2x2 it's not needed anymore.
Old 07-06-2013, 09:00 PM
CRAZY_RUSSIAN's Avatar
what scanner do you have?
xcabin84
10
05-10-2008 07:29 PM
lilkitten
03-13-2006 05:57 PM
88audi90_Q
24
04-17-2003 08:52 AM
Bruch
09-19-2002 05:27 PM
Robjared
Misc. Models Discussion
06-24-2001 05:55 PM
Quick Reply: 93 90 cs won't start
