aftermarket wheel?
Old 05-08-2016, 05:48 PM
mrprism133's Avatar
Default aftermarket wheel?
has anyone tried to mount 4x108 wheels for the older mustangs, or ford focus, or anything similar? bummed about the lack of/ to basically no choice for wheels
Old 05-08-2016, 08:43 PM
yakimatdi's Avatar
Default Aftermarket Wheels
I had these on my cab before I restored my Audi EOM competition wheels. They are Sport Edition 16 X 7.5 inch. I bought them at Tire Rack a few years ago. Now discontinued. Inexpensive.
Let me know if these interest you.
Old 05-08-2016, 10:12 PM
CRAZY_RUSSIAN's Avatar
tire rack has a good selection of rims and yes, wheels from an SVT Focus fit but require spacers for greater offset
and here are my babies, and no, can't have them :-P
Old 05-09-2016, 03:38 AM
mrprism133's Avatar
how thick are the spacers?
Old 05-09-2016, 12:11 PM
not a slightest clue find the wheels you like, and see how thick of a spacer you need
Old 05-10-2016, 04:16 AM
mrprism133's Avatar
ok i get what you are saying. use a spacer to get the offset back to within specs
Old 05-10-2016, 03:38 PM
yep you need to avoid having your tires hitting your strut/shock/tie rod ends. also a wheel that's sticking out too far will cause a premature wear on the wheel bearing. also, don't forget that sidewall of a tire flexes under corners, so you want to have at least 15+mm to accommodate for that http://billavista.com/tech/Articles/...dial_tread.jpg
Old 05-11-2016, 10:32 AM
visatrade's Avatar
I know everyone mods rims/tires these days but be warned about messing around with the "Scrub Radius."
As I recall, (from the Brakes, Steering, Suspension Course I took) if the scrub radius is incorrect and one of the two cylinders fails in the master cylinder, your car will not brake in a straight line and it may throw you off into a wall or another car.
On my RX-7 previous owner put stock rims in the front and some different rims/tires in the rear. When I go over slight bumps on the freeway, my back end bounces all over the place and loses grip.
There also are some videos on youtube cautioning against using spacers since they add strain to your suspension, drivetrain, and A-Arms.
wheelin33
Wheels & Tires Discussion
04-08-2012 08:40 AM
DoubleA4
Audi allroad
10-12-2011 04:17 AM
janB7
A4 (B7 Platform) Discussion
12-02-2005 05:54 AM
Jeff_URS6A
Audi allroad
01-14-2005 01:55 PM
R2.7TA6
Rocky Mountain Discussion
11-07-2004 02:42 PM
Quick Reply: aftermarket wheel?
