Headlights and cruise out.
Old 11-27-2013, 05:19 PM
Tyson2busy's Avatar
Default Headlights and cruise out.
Hey guys, newbe here with a red '93 90CS at 140K miles.
My cruise control has been out for a few weeks now but I hadn't bothered to check the fuse.
-Today as I was on a road trip I noticed a very slight burning smell.
*** It get's dark and I realize my headlights are out. Thank God that at least both fogs work. High beams still work.
-I also notice that when I activate the left turn signal, the high beams come on. Or, if I push the cruise control activation, the high beams also come on. This does not seem to happen if I only have the parking lights on.
-All fuses are good.
Please help? Not sure what to do. On a tight budget so I'd like to DIY if possible. A recommendation of who to order parts through would be appreciated as well.
HAPPY TURKEY DAY!!!
Old 11-27-2013, 06:15 PM
CRAZY_RUSSIAN's Avatar
ow boy... 3 things come to my head, ignition switch, trunk wiring harness and the switches on the steering wheel. i would start with the trunk wiring harness as its the cheapest ;-) STFA for more info on those
Old 11-27-2013, 08:06 PM
Tyson2busy's Avatar
Sorry,...what's STFA?
And thanks for the help. Anyone else have any other ideas?
Old 11-27-2013, 08:16 PM
STFA - search the forum archives, or something different for "F" :-)
check out one of my posts towards the end, it describes the trunk wiring harness https://www.audiworld.com/forums/sho...2824806&page=2
Old 11-29-2013, 01:39 PM
Tyson2busy's Avatar
So I pulled the cover off steering wheel column and just jiggled the wires around. It got my low beams to come on but the high beam still comes on when I use my left turn signal. Just ordered a new steering column switch off EBay. Hopefully that cures it. I'll also replace the ignition switch at the same time. Gotta do some research on what to buy and how to DIY now.
Thanks for the guidance. I'll probably check the rear wiring harness as you suggested as well.
Old 11-30-2013, 07:42 PM
keep us posted man:-)
Old 01-28-2014, 10:42 PM
Tyson2busy's Avatar
So finally got around to fixing this.
Found a new steering wheel light/ cruise control switch at Autohaus on sale.
Had to take steering wheel off to change it- found a DIY on replacing the steering wheel.
The wiring clip was slightly damaged so I had to push the wires into the switch to get good contact.
Works fine now.
deadboltpoison
NY / NJ / CT Discussion
09-28-2015 05:01 PM
mxp
09-26-2015 10:15 AM
havocgb
09-25-2015 04:50 PM
changareth
09-25-2015 11:27 AM
N_Jay
09-25-2015 05:04 AM
Quick Reply: Headlights and cruise out.
